Fault code P0031
19 Aug 2015 20:31 #150210 by skywalker65
Fault code P0031 was created by skywalker65
Hi all,
Another Noobie question for the collective.
Usual story .. Engine check light on so read the fault code and got the above code P0031 which states its HO2S heater control circuit bank 1 .
I can clear the fault but it comes back on after ignition off then on again and the car running .
I'm assuming it's a lambda sensor issue.
Mine is a VVT model and has 2 sensors. 1 in the exhaust manifold itself and the other further down towards the other cat.
Any ideas to which one the fault code is referring to please ??
If in doubt ...... Flat out ??
  • fozzie
19 Aug 2015 20:37 #150211 by fozzie
Replied by fozzie on topic Fault code P0031
Found this if it helps...
Possible causes
- Faulty Heated Oxygen Sensor (H2OS) Bank 1 Sensor 1
- Heated Oxygen Sensor (H2OS) Bank 1 Sensor 1 harness is open shorted to ground
- Heated Oxygen Sensor (H2OS) Bank 1 Sensor 1 circuit poor electrical connection
- Heated Oxygen Sensor (H2OS) Bank 1 Sensor 1 circuit fuse
- Faulty Engine Control Module (ECM)
Tech notes
The code means that there is a problem with the heater element circuit of the heated oxygen sensor. Water getting inside the heated oxygen sensor connector can caused the heated oxygen sensor fuse to blow, which is a very common problem for this type codes. Before replacing the sensor, check for the condition of the heated oxygen sensor fuse and connectors.
Read more: engine-codes.com/p0031_suzuki.html#ixzz3jINCTjWj
19 Aug 2015 20:44 #150214 by skywalker65
Replied by skywalker65 on topic Fault code P0031
Thanks Fossie.
Is the fuse for the heater located in the fuse box next to the battery.
Only got the car recently and still finding my way around it
  • iloveics
19 Aug 2015 21:08 #150216 by iloveics
Replied by iloveics on topic Fault code P0031
Bank 1 should be pre-cat
  • fozzie
20 Aug 2015 05:23 #150222 by fozzie
skywalker65 wrote: Thanks Fossie.
Sorry, I'm in the same boat as you! I'm relatively new to the Jimny.
20 Aug 2015 07:40 #150224 by facade
Replied by facade on topic Fault code P0031
It is the one on the exhaust manifold, a new one is £20 on eBay, £40 if you want a cheap one that says denso on the barrel.
The £20 ones work fine for years, mine has had one for 5 years and passed MOT yesterday with lambda 1.00.
You have to cut your plug off and crimp the wires from the new one to the old- don't cut the plug end too short in case you have to do it again.
Time to create page: 0.096 seconds
