Castor correction
  • Jack
09 Nov 2010 17:59 #5831 by Jack
Castor correction was created by Jack
OK ive fitted a 3" lift from Kap,235/75x15 kumho M/T,15X7 Black mod wheels,looking good,now i need to sort out the castor correction,C'os my better half refuses to drive it,i thought about changing the bushes but ive heard they dont make much difference with a 3" lift,so im looking at replacment arms,OR ive just seen Martins pics of welding up the axle, & its got me thinking could i extend the front of that bracket, redrill the hole lower down & castor correction done. what do you think,:whistle:
  • Garry
09 Nov 2010 19:38 #5833 by Garry
Replied by Garry on topic Re: Castor correction
dont be drastic by changing the lenght of the arms,
the castor correction bushes will do the job, a few of my mate have lifts, anything from 2" to 4.5", those with 3" or more have fitted the bushes and they all work fine.
  • Jack
09 Nov 2010 20:06 #5836 by Jack
Replied by Jack on topic Re: Castor correction
Thanks for your reply Garry, but its not the lenght of the arms i was thinking about changing, its the bracket they bolt to,take a look at martins pic,on home page,(24/10/10 - Welding up the Axle) He has welded a washer on that bracket,if that hole was say half inch lower,that would sort castor problems out.
09 Nov 2010 20:08 #5837 by mlines
Replied by mlines on topic Re: Castor correction
The general feeling is that castor correction bushes are good for 2" lift only although they will improve a 3" lift.
There is a standard "re-drilling" the holes modification to achieve the same effect and there are some measurements somewhere on the Internet. I have a feeling Gary - FunkJimny - did this on one of his Jimnys.
  • Jack
09 Nov 2010 20:32 #5839 by Jack
Thanks Martin ive just been looking on the net but cant find anything,i will have another look 2morrow, i do like your ora arms,
10 Nov 2010 13:45 #5847 by kirkynut
Replied by kirkynut on topic Re: Castor correction
I think I would just buy ORA arms - more expensive but you get stronger arms with a lifetime warranty and far less hassle.
Time to create page: 0.261 seconds
