Wheel stud
  • Solas
08 Aug 2015 18:32 #149429 by Solas
Wheel stud was created by Solas
Tightening up the wheels today after changing them and snap! Wheel stud gone. I have 32mm spacers so it's one of the adapter studs, anyone know where I can buy a couple?
  • irishguy123
08 Aug 2015 18:52 #149434 by irishguy123
Replied by irishguy123 on topic Wheel stud
If they're 32mm I think they're probably these ones from Jimny Bits: www.jimnybits.co.uk/shop/wheel-nuts-bolt...n-studs/prod_72.html
  • Solas
08 Aug 2015 20:43 #149455 by Solas
Replied by Solas on topic Wheel stud
irishguy123 wrote: If they're 32mm I think they're probably these ones from Jimny Bits: www.jimnybits.co.uk/shop/wheel-nuts-bolt...n-studs/prod_72.html
Ordered! Thanks again for the help lads!
  • Solas
11 Aug 2015 14:22 - 11 Aug 2015 14:44 #149638 by Solas
Rhinoman wrote: Was it over-tightened? I would be concerned, if the other studs are stretched then you could end up with a wheel coming adrift.
Not sure, think I may have over tightened it! Now you got me concerned! Anyone know what the torque setting are for wheel studs?
Last edit: 11 Aug 2015 14:44 by Solas. Reason: Miss spelled duh!
  • gusthegorilla
11 Aug 2015 17:13 #149642 by gusthegorilla
Replied by gusthegorilla on topic Wheel stud
Normally 95nm, Solas...I assume you mean for the wheel nuts
Gus :)
  • Solas
12 Aug 2015 10:49 #149674 by Solas
Thanks Gus, will torque them up to day! Doing an 80 mile commute just now so really don't fancy a wheel passing me.
Time to create page: 0.154 seconds
