Wheel Spacers
  • BrynHIMself
22 Jul 2015 09:34 #148234 by BrynHIMself
Wheel Spacers was created by BrynHIMself
Thinking of getting some wheel spacers. Any tips or advice? or any issues i need to be aware of. Thanks in advance...
22 Jul 2015 09:52 #148235 by Jezz
Replied by Jezz on topic Wheel Spacers
Make sure the thread and pitch of the stud size is correct ( Jimmy is m12×1.25 metric fine).
There are two basic types, Hollow ring with extension studs (much cheapness in price and my own opinion quality).
Or the solid ring type with pressed in studs, More expensive but again in my opinion better design and better quality and fit. I personality would go with the solid type, But that's just me. B)
It's been fettled just a tad.
The following user(s) said Thank You: BrynHIMself
  • BrynHIMself
22 Jul 2015 10:01 #148236 by BrynHIMself
Replied by BrynHIMself on topic Wheel Spacers
No eBay APP ID and/or Cert ID defined in Kunena configurationwas just going to get 10mm or maybe even 5mm spacer like these below
Are they as simple to put on as they look?
22 Jul 2015 10:15 #148240 by Jezz
Yes is the simple answer.
But you need to make sure there is still enough of the threaded wheel stud showing to bolt the wheel up.
22 Jul 2015 12:39 #148249 by Busta
Replied by Busta on topic Wheel Spacers
For what purpose are you fitting them? Unless you need them for tyre clearance, wheel spacers are entirely pointless. Especially ones as narrow as 5mm! At best you will fit them and see no difference. At worst, you will forever have balancing/death wobble issues as the wheel won't centre on the hub as well as it should.
22 Jul 2015 17:47 #148273 by Jezz
Suzuki are stud centric, So that spacer shouldn't be a problem. But I agree with it being pointless unless needed for clearance.
Time to create page: 0.116 seconds
