Electric window won't go up (but goes down)
- spandit
21 Jul 2015 11:02 #148170
by spandit
Electric window won't go up (but goes down) was created by spandit
Was driving my sister around the field today and we put the passenger window down. Once we'd finished, it wouldn't go up again. It would go all the way down and I've had to take the bl**dy door card off to access the wiring. By wiring a battery directly to the motor connector, I can drive it back up again but plugging the switch in only allows me to wind it back down again.
Is this likely to be a switch problem? Not sure where the 5 wires from the switch go - presumably to a relay somewhere (only 2 make it as far as the motor). The wiring diagram I have doesn't have the electric window motors on it...
21 Jul 2015 11:13 #148172
Replied by Daniel30 on topic Electric window won't go up (but goes down)
Can you swap the switch from the drivers side to test weather it's a switch problem or something else?
21 Jul 2015 18:10 #148195
by kirkynut
Replied by kirkynut on topic Electric window won't go up (but goes down)
My money's on the switch.
21 Jul 2015 19:31 #148202
by j999pre
Grey pick up Jimny
Replied by j999pre on topic Electric window won't go up (but goes down)
I have a switch
Grey pick up Jimny
21 Jul 2015 20:00 #148205
by minibbb
Same issue I had and I got a replacement switch from j999pre (James) works a treat now
Replied by minibbb on topic Re:Electric window won't go up (but goes down)
j999pre wrote: I have a switch
- gusthegorilla
21 Jul 2015 20:26 #148210
by gusthegorilla
MY money was on you saying you have a box full, James....but you beat me to it :sick:
Replied by gusthegorilla on topic Electric window won't go up (but goes down)
Time to create page: 1.237 seconds
