Kingpin change problems
- oxford_bloke
16 Jul 2015 11:57 #147823
by oxford_bloke
Kingpin change problems was created by oxford_bloke
do you have a set of "metric inch" spanners the ones with small ridges on the flats of a rind spanner. They grip the flats of the bolt and not the edges.
Could try hammering a slightly smaller old socket on to it,
Weld a bar to it
a hell of a lot of penitrating fluid or freeze spray,
if it has a nut use a nut splitter.
drill it out.
these are things i have done in the past and have worked.
Weld a bar to it
drill it out.
16 Jul 2015 12:15 #147824
by j999pre
Grey pick up Jimny
Replied by j999pre on topic Kingpin change problems
You don't need to split the hubs or backplates just remove one big lump
Grey pick up Jimny
- wombat
16 Jul 2015 14:56 #147832
by wombat
Replied by wombat on topic Kingpin change problems
if you want the backplate off for good just cut it off
- Grego
16 Jul 2015 16:56 - 16 Jul 2015 16:59 #147835
by Grego
Replied by Grego on topic Kingpin change problems
In the 70s/80s, I had a couple of Suzuki bikes.
I soon learned that nothing could be undone without an Impact Driver and a set of Impact sockets(hex as opposed to bi-hex), and the end of the sockets were ground flat to remove the curved lead so a bolt head would be covered 100 %.
The Japs had the designs but the metal they used for bolts and screws was shocking :woohoo:
Worth the investment if you're having trouble with bolts (and don't forget the blow torch).
Last edit: 16 Jul 2015 16:59 by Grego.
- gusthegorilla
16 Jul 2015 18:05 #147839
by gusthegorilla
Replied by gusthegorilla on topic Kingpin change problems
These were recommended to me last year by a Forum member....in over 40 years of buggering about with cars, they are probably the finest single investment I ever made..... worth their weight in gold
And, there's an upgrade set available ,too.
www.screwfix.com/p/irwin-bolt-grip-nut-r...r-set-5-pieces/96028
Gus
I just picked this ad for the picture...other suppliers are available :whistle:
Gus
16 Jul 2015 18:38 #147841
by Jezz
It's been fettled just a tad.
Replied by Jezz on topic Kingpin change problems
Have to agree with Grego, Good quality single hex sockets and you'll very rarely have a buggered nut or bolt.
Time to create page: 0.103 seconds
