Need Help - Head Gasket v's crack in block
- Chris the Phys
07 Jun 2015 10:26 #145583
by Chris the Phys
Need Help - Head Gasket v's crack in block was created by Chris the Phys
Hi all (This may be a silly Q?) :blush: - I need a little bit of advice please - this there a test/way to find out if the head gasket as gone or there is a crack to the block?
The reason is I was thinking about buying another jimmy and my son and I doing it up as a project - therefore need to know it I need to do the gasket or replace the engine?
Thanks in advance
Thanks in advance
07 Jun 2015 10:47 #145585
by facade
Replied by facade on topic Need Help - Head Gasket v's crack in block
There is a "sniffer" test that checks for hydrocarbons in the water, which will tell you if there is a crack from inside the cylinder to the waterways, which is normally head, or headgasket.
Unless the engine has frozen in the winter the block won't be cracked, and you would see where the water had been coming out if it was.
You could have a warped head, or a cracked head to go with the headgasket though.
The following user(s) said Thank You: Chris the Phys
- Chris the Phys
07 Jun 2015 11:03 #145587
by Chris the Phys
Replied by Chris the Phys on topic Need Help - Head Gasket v's crack in block
The seller says that the Jimny has been sitting around for the last 18 months, when he got the vehicle the seller said that it had no anti freeze !!! however I show the jimmy yesterday and it started 1st time and I didn't see any water leak.
Am I right in thinking a cracked engine means a replacement one?
- OllieNZ
07 Jun 2015 11:09 #145589
by OllieNZ
Replied by OllieNZ on topic Need Help - Head Gasket v's crack in block
Depends where the crack is. An engine shop may be able to weld an external crack. What year/engine is the jimny?Chris the Phys wrote: The seller says that the Jimny has been sitting around for the last 18 months, when he got the vehicle the seller said that it had no anti freeze !!! however I show the jimmy yesterday and it started 1st time and I didn't see any water leak.
- Chris the Phys
07 Jun 2015 11:18 #145591
by Chris the Phys
X Reg
Not sure about engine
- OllieNZ
07 Jun 2015 11:45 #145592
by OllieNZ
Replied by OllieNZ on topic Re:Need Help - Head Gasket v's crack in block
Time to create page: 1.453 seconds
