check engine light
  • Garry
06 Nov 2010 14:17 #5767 by Garry
check engine light was created by Garry
just went and took my jimny a run, the engine seems fine now, but the check engine light is on.
any ideas what has caused the light to stay on?
everything is working as normal.
  • Bigchridy
06 Nov 2010 16:01 #5769 by Bigchridy
Replied by Bigchridy on topic Re: check engine light
The light could be on for any number of reasons. I take it the light that is on is the yellow engine management light?
There may be a present trouble code stored in the ECU. If it was present you would expect to see some sort of fault whilst driving the truck. There are several trouble codes that will keep the light on even if they are not present. These are usually fuel/exhaust related (eg o2 sensors).
You could really do with getting hold of someone with a fault code reader to see what the exact code is then someone on here will probably be able to give you an idea of what component has failed.
Hope this helps.
Chris
  • Garry
06 Nov 2010 16:13 #5770 by Garry
Replied by Garry on topic Re: check engine light
Thanks buddy, i dont have anyway to check the codes, so will have to either get someone to do it for me, or stick a bit of black tape over the light :laugh:
  • Bigchridy
06 Nov 2010 16:49 #5772 by Bigchridy
Black tape sounds good to me! Just read your other post about doing an engine swap! Sounds like fun to me!!!!:laugh:
Time to create page: 0.368 seconds
