Rear disc brake conversion
  • Dave!
24 Apr 2015 20:06 #143102 by Dave!
Rear disc brake conversion was created by Dave!
So many of you may of recently seen an s reg jimny come up for sale on gumtree and dotted around kirton off road.
Well i recently purchased it and had a rear disc brake conversion on it, we cant really seems to find much info about the motor or what discs and callipers are actually on it.
What rear disc conversions do people do?
Regards,
Dave
  • Nicks_Jim
24 Apr 2015 20:10 #143103 by Nicks_Jim
Replied by Nicks_Jim on topic Rear disc brake conversion
pictures !!!!
  • Dave!
24 Apr 2015 20:34 #143105 by Dave!
Replied by Dave! on topic Rear disc brake conversion
  • rogerzilla
24 Apr 2015 21:55 #143112 by rogerzilla
Replied by rogerzilla on topic Rear disc brake conversion
There is a kit which uses Renault Megane calipers. Could it be one of those?
25 Apr 2015 07:36 - 25 Apr 2015 07:39 #143121 by jackonlyjack
that looks like a rover 400 series rear calliper ;)
ebay 121505509002
Last edit: 25 Apr 2015 07:39 by jackonlyjack.
  • whittleos
25 Apr 2015 08:23 #143123 by whittleos
Replied by whittleos on topic Rear disc brake conversion
hi i have done it to mine . using sj front hub flange cut a peace out of one side so slips over the axle at its smallest point then slid it up to the back of the hub flange . then when when replaces wheel bearings took the back plate off that the drum shoes sit against off and cut it so its square leaving the four bolts still there then tapped them out . and replaced with longer once that will then go through the axle flange and the hub part used to mount the calliper and fitted new bearing on .then used jimny front disk and pads and calliper as they bolt right on ect . then put my hand brake to my transfer box . can also put disk on there if wanted but i use the t-case so it already had it on so used it . can get pics if wanted or there is other options above
