Fitting spring spacers
- Nelson83
05 Nov 2010 19:57 #5745
by Nelson83
Fitting spring spacers was created by Nelson83
Has anybody fitted the spring spacers from Dave @ bits4vits? I'm considering getting some and just wondered how easy they are to fit. I had a look at his fitting manual - the rear axle seems to be a piece of cake - loosen the shock off and slot the spacer in and tighten up. Would the front be as easier seeing as they both live axles - the manual on the website only shows the fitting for the vitara which is slightly different. I'd feel confident to do the rear, but if the fronts different, i'd have to seek a bit more help.
Any advise would be appreciated
- Adamski
05 Nov 2010 20:20 #5748
by Adamski
Replied by Adamski on topic Re: Fitting spring spacers
I haven't fitted spacers but have fitted a full lift kit and the front was just as easy as the back to change the springs, which i guess would be exactly the same for the spacers. The hardest part is getting the bolts off as pretty much all of mine were seized solid. I managed to get all but 1 undone (using extreme brute force) which required an angle grinder and a new bolt from Suzuki.
You will probably have to disconnect the brake lines to allow the axle to drop far enough to get the springs out, unless you use spring clamps, which I didn't.
- Garry
05 Nov 2010 20:58 #5750
by Garry
Replied by Garry on topic Re: Fitting spring spacers
yip the front is just as easy as the rear, word of warning though, soak the bolts in wd40 the day before you plan to do it, my mate didnt and sheared the 2 rear bottom shock bolts.
the whole jimny is super easy to work on, the only part ive not had off/out yet is the engine, but thats coming out this weekend hopefully.
- Nelson83
05 Nov 2010 21:04 #5752
by Nelson83
Replied by Nelson83 on topic Re: Fitting spring spacers
Cheers guys!!! Im fairly confident i can do it, just wasnt sure if the front and rear axles were the same.
- Mick C
06 Nov 2010 08:37 - 06 Nov 2010 08:38 #5756
by Mick C
Replied by Mick C on topic Re: Fitting spring spacers
I fitted 2" spacers and shock extensions and found the front a touch easier than the back for some reason.
I already had spring compressors which I used to get a little bit of compression to help get the springs out and back in, but you don't really need them.
As always, and as already stated, the biggest stress is undoing seized fasteners
Last edit: 06 Nov 2010 08:38 by Mick C.
- Nelson83
06 Nov 2010 09:16 #5757
by Nelson83
Where did you get the shocker extensions from mick?
Time to create page: 0.168 seconds
