g13bb from metal top to cabrio???
  • nikos_trd
16 Apr 2015 18:35 #142627 by nikos_trd
g13bb from metal top to cabrio??? was created by nikos_trd
hello,the engine g13bb have differences from cabrio to metal top.the cabrio g13bb has a crank sensor under the oil pump.so oil pump,and oil sump are different.also the camshaft is different.anyone know if I put a engine g13bb from metal top to cabrio it will work?
16 Apr 2015 19:41 #142639 by j999pre
You will need to use the cabrio sump, inner crank pulley and drill an 18mm hole for the sensor. Also you will need to use the Castro cam shaft or swap the pick up over on the end. Other than that it is a straight swap,
Grey pick up Jimny
  • idiotmobil
16 Apr 2015 19:56 #142645 by idiotmobil
Replied by idiotmobil on topic g13bb from metal top to cabrio???
Some are exactly the same as a tin too mine was
Time to create page: 0.193 seconds
