psi
11 Mar 2015 16:30 #140371
psi was created by Daniel30
This might be a silly question but if you put different tyres on your jimny like my general grabber AT how do I know what psi they should be inflated to :blush:
11 Mar 2015 17:25 #140376
by Halford
in my grabber ATs (205's) I run 24/27 on the road which gives me a good ride and grip, running a touch higher psi would improve fuel consumption albeit at the expense of comfort and grip. Obviously for off-road drop the pressures. The actual psi you'll find best for you will need experimentation .................
try different psi's (keep the 3 psi difference between front and rear), and see what's best for you ... it'll give you an appreciation as to how critical psi is and will let you "feel" how the truck reacts making you more sensitive to the road.
have fun
have fun
- Thank you received: 706
11 Mar 2015 18:08 #140380
Replied by jackonlyjack on topic psi
i put 25 all round
i just checked the foot print of my tyre
using 2xa4 sheets of paper
one each side of tyre front to back
then measured tyre width
and made a equal square bit strange i know but hey-ho thats me
tyre size 195 80 15
tyre size 195 80 15
11 Mar 2015 18:29 #140381
Replied by Daniel30 on topic psi
Cheers guys will have a play about as not really thought about it until I was browsing though some old posts on here.....
.great advice as usual
11 Mar 2015 18:49 #140384
by Halford
I've seen others do this and in it's place I think it could be useful,
the problem lies with our rigid chunky AT tyres ......
a several psi difference just isn't going to show any difference on the paper
jackonlyjack wrote: i just checked the foot print of my tyre
tyre size 195 80 15
- Thank you received: 2004
11 Mar 2015 19:37 #140391
Any given tyre will have a maximum weight at a maximum pressure embossed on the sidewall, this can be used to reverse calculate the pressure for a given load. So look on the vin plate for the maximum permitted axle weight for each axle, divide that by 2 to get the maximum load per tyre, now use the information on the tyre to determine the psi per kg that the tyre can handle and multiply that by the maximum load per tyre you worked out from the vin plate. It will in all probability be within a few psi of the handbook recommended figures. Hope that makes sense.
The following user(s) said Thank You: Daniel30
Time to create page: 0.109 seconds
