Vacuum hubs picture engaged hubs
- Chris de Raat
02 Mar 2015 09:42 #139566
by Chris de Raat
Vacuum hubs picture engaged hubs was created by Chris de Raat
Dear forum members,
A month ago I bought a Jimny for our daughter to drive in.. ( and for me fun as well as a project to "restore" and ofcoarse to drive offroad)
The one item I seem not to be able to fix myself are the vacuum hubs..(I read all the posts...)
Replaced the vacuum hoses, checked the valves, vacuum switch etc and everything seems to work (you can hear the vacuum in the hubs) but no physical engaging of the hubs unfortunality.. Removing the black "air locking hub assembly" shows a nice clean axle, circlip and thrust washer etc..but should it be possible to engage the hub manually?
If someone has a picture of can explain me what should move you would help me a lot..
I have the technical manual wich was a great help to check all the electronic components but it gives me not a clear idea if the next step is to remove the wheelbearing or if I can fix it without doinng that..
- fast forward
- Elite Member
- Thank you received: 7
02 Mar 2015 19:48 #139654
by fast forward
if you cant go round it go over it ! or vice versa ?
Replied by fast forward on topic Vacuum hubs picture engaged hubs
my vac hubs have packed in and all the recent snow in sheffield yes i put it in 4wd manually by undoing the 6 bolts on each front hub and wobbling the cogs in each hub till they pop out then fix them back on opposite to put back into 2wd bit cold on fingers in the snow but better than getting stuck :blink:
- Butta
02 Mar 2015 20:24 #139659
by Butta
Replied by Butta on topic Vacuum hubs picture engaged hubs
- Johnniehec
- Thank you received: 56
02 Mar 2015 21:25 #139671
by Johnniehec
Mine have been locked like this and the pipes on the back of the hubs blocked off to stop the water getting in for about two years, no need to take them apart and "unlock' them, 4wd is disconnected when you move the transfer lever , or button, back to 2WD.
Replied by Johnniehec on topic Vacuum hubs picture engaged hubs
fast forward wrote: my vac hubs have packed in and all the recent snow in sheffield yes i put it in 4wd manually by undoing the 6 bolts on each front hub and wobbling the cogs in each hub till they pop out then fix them back on opposite to put back into 2wd bit cold on fingers in the snow but better than getting stuck :blink:
- polony
03 Mar 2015 13:28 #139733
by polony
Replied by polony on topic Vacuum hubs picture engaged hubs
No need to unlock except that you are dragging your front driveshaft and axle along for the ride, so you will see increased wear there and worse fuel economy.
03 Mar 2015 14:12 #139738
Replied by mlines on topic Vacuum hubs picture engaged hubs
This blog post here shows the hubs in a locked and unlocked position
bigjimny.com/index.php/entry/150-51009-f...in-the-field-v15-208
The following user(s) said Thank You: Tadpole, Chris de Raat
Time to create page: 0.257 seconds
