Split charge
  • rexthecat
11 years 9 months ago #138268 by rexthecat
Split charge was created by rexthecat
foundry4x4.co.uk/index.php?route=product..._1760&product_id=173
Am i right thinking this will be ok to wire batteries in parallel using this? Basically the 2 batteries wont ' steal' from each other and eventually go flat using this? Would the batteries need to be the same?
Cheers
  • TomDK
11 years 9 months ago #138269 by TomDK
Replied by TomDK on topic Split charge
Correct.
But do you really need it?
Of you have a pair of good quality batteries there's no need for a relay like this.
  • suzuki jimny fella
11 years 8 months ago #138481 by suzuki jimny fella
Replied by suzuki jimny fella on topic Split charge
i am about to do a duel battery set up with tmax split charger as said above dose it mate if the batterys are different sizes
11 years 8 months ago #138482 by suzuki jimny fella
i have a yts 2.7 yellow top in standard tray and thinking on getting a yellow top yts 4.2 for second tray connected with tmax split charger will this be ok
  • rexthecat
11 years 8 months ago #138531 by rexthecat
Replied by rexthecat on topic Split charge
Aye cheers. I was going to put the battery in the back as no room under the bonnet now. Would I be able just to earth the second battery somewhere in the back. The jimny electric systems a bit baffling!
Cheers
  • Russ-41
11 years 8 months ago #138545 by Russ-41
Replied by Russ-41 on topic Split charge
What is that thing anyway? It looks like just a standard 200A relay, you should get change out of £10 including delivery for a good one.
Also, do not use the alternator/charge light wire as the instructions included with the kit might well suggest, it forbidden in the Jimny Manual to attach anything to that wire, no idea why but if they went to the trouble of making the point, there must be something behind it.
I was looking at a Durite 140A split charge relay, it senses the voltage on the line and automatically turns on and off - no wiring into the loom or anything, just fit it inline on the +ve and earth it via the mounting bolts- done.
Link
And thats my planned wiring setup but I haven't done it yet. I got conned on ebay, paid good money for 25mm2 cable, was sold as 170A, turns out its max safe was less than 80A, it wasn't even copper core (it was copper coated aluminium) I went to WECS in Sheffield and picked up 10 meters of 25mm oil and petrol resistant silicone cable, the difference in quality is remarkable and it was only £28 inc. VAT, I think they charge a little more delivered Link
Time to create page: 0.103 seconds
