low range question/help
11 years 9 months ago #136703 by Busta
Replied by Busta on topic low range question/help
It's hard to spin the wheel because you have 4 wheel drive and not a lot of power. I don't mean it'll never spin, just that you don't need to be concerned about low gears making you break traction.
One of the mains benefits of wheel slip is that it helps clear the tyre tread of mud so you the tyre can dig and find traction.
If you want to get to grips with the basics of driving offroad, watch a few videos like this. Ignore all the bit's about Landrovers being great though- it's not true.
  • jimny dave
11 years 9 months ago #136714 by jimny dave
Replied by jimny dave on topic low range question/help
Thank you for the replies its really helping me:)
I have seen that video before but I think I will recommend watch it having no a new.mind set and thoughts about all the technicalities it may well help :) cheers all! All I can say is I wish I Had my own to play with and learn a bit more.
Your in put is great so thank you :)
Atb dave
11 years 9 months ago #136716 by Rhinoman
Replied by Rhinoman on topic low range question/help
What drives the car along is the amount of torque at the contact patch of the tyre. That is a function of the torque at the flywheel multiplied by the overall gearing and also the diameter of the tyre. Lower gearing has two effects, it increases the torque at the rear wheel by modifying the multiplier and also it increases engine RPM which increases the torque at the flywheel.
  • TomDK
11 years 9 months ago #136721 by TomDK
Replied by TomDK on topic low range question/help
Rhinoman wrote: What drives the car along is the amount of torque at the contact patch of the tyre. That is a function of the torque at the flywheel multiplied by the overall gearing and also the diameter of the tyre. Lower gearing has two effects, it increases the torque at the rear wheel by modifying the multiplier and also it increases Engine RPM which increases the torque at the flywheel.
Power, not torque.
11 years 9 months ago #136764 by Rhinoman
No torque, torque is the rotational force and that's what pushes the car along.
  • TomDK
11 years 9 months ago #136774 by TomDK
Rhinoman wrote: No torque, torque is the rotational force and that's what pushes the car along.
Yes I suppose you're right :blush: :)
Time to create page: 0.088 seconds
