jimny axles to samurai chassis
23 Jan 2015 10:45 #135838 by nikos_trd
hello,i have a Suzuki samurai full of rust.the samurai have arbs front and rear and HD front axle shafts and cv's and rear.and I am thinking to buy a cheap jimny to put the arbs and the HD front axle shafts and cv's to jimny axles...it can be done?what is your opinion?
  • steffan
23 Jan 2015 10:53 #135840 by steffan
Replied by steffan on topic jimny axles to samurai chassis
Personally ad put the Sammy axles on the jimny as I believe there slightly stronger
23 Jan 2015 11:02 #135842 by nikos_trd
yes but the samurai axles have springs and the jimny coils....I prefer coils,more comfortable,so anyone knows if I can match the inside of axles...(axles shafts,etc....)to jimny axles???thanks!!!
  • TomDK
23 Jan 2015 11:05 #135844 by TomDK
Replied by TomDK on topic jimny axles to samurai chassis
The Samurai internals wont fit in the Jimny axles. So you're much better of just making some coil spring seats on the samurai axles.
23 Jan 2015 12:14 #135856 by Busta
I think the only thing that will fit the Jimny is the rear ARB. The Jimny axles are wider and the front diff is smaller.
  • steffan
23 Jan 2015 16:47 #135872 by steffan
Cut the moutings Off the jimny axle and weld onto the Sammy axles problem solved
Time to create page: 0.338 seconds
