Intermittent poor cold start
  • Caulkheader
22 Jan 2015 17:10 #135731 by Caulkheader
Intermittent poor cold start was created by Caulkheader
Hi - I have a 64 pate Jimny, my second one. Its done 3k so far. Recently its failed to start first crank when cold and when it does its missing like hell for the first couple of seconds and occasionally when its still warming up it misses.
I didn't have the problem with my old Jimny and the dealer is suggesting they all do it, they won't scan for fault codes. I am going to try a more local dealer as its obviously under warranty.
I wondered if any one on here has any ideas that I could suggest to them when I take it in.
Cheers
  • gusthegorilla
22 Jan 2015 18:29 #135746 by gusthegorilla
Replied by gusthegorilla on topic Intermittent poor cold start
You shouldn't be having to make suggestions to them, mate, just raise the subject of "Trading Standards", I think you may then get a somewhat different response :)
22 Jan 2015 22:05 #135792 by mlines
Our 55 plate VVT is as sweet as a nut to start even in the cold weather, so the dealer is talking sh*t. Even my 03 plate that last ran in October 2013 started and ran OK the other week
Sent from my Nexus 5 using Tapatalk
The following user(s) said Thank You: Caulkheader
  • BigT
23 Jan 2015 08:44 #135831 by BigT
Replied by BigT on topic Intermittent poor cold start
gusthegorilla wrote: You shouldn't be having to make suggestions to them, mate, just raise the subject of "Trading Standards", I think you may then get a somewhat different response :)
Just tell them your problem and to repair it, they are legally bound to rectify faultts under warranty.
  • Caulkheader
23 Jan 2015 09:05 #135832 by Caulkheader
Replied by Caulkheader on topic Intermittent poor cold start
Cheers -
Its going in next week, different dealer will scan the OBD's
I have found another post on here with a similar issue but no resolution. Keep you posted.
  • Caulkheader
23 Jan 2015 19:00 #135876 by Caulkheader
Had a call back from the local (better) dealer today. It appears that they have another 64 plate Jimny with exactly the same problem. It is weather related and is either ignition or fuel. As it can't be replicated (it's intermitent) they are escalating it to Suzuki technical. Will keep you posted.
