has anyone done a electric cooling fan conversion?
- S Mark
23 Nov 2014 17:26 #130432
by S Mark
has anyone done a electric cooling fan conversion? was created by S Mark
As above really has anyone done a electric cooling fan conversion. I think it's a really good modification to do away with the viscous fan, with a three way switch. On, off and normal working of a temperature sensor. On for when you no your going to be giving it 100% up a hill or stuck in mud, off for when your going to do a water crossing.
So has anyone done it? What parts did you use and haw did it work out. Or just people's thoughts? Knowledge of any kits available?
23 Nov 2014 18:06 - 23 Nov 2014 18:08 #130437
by dirtydogz
2002 JLX Soft Top
Replied by dirtydogz on topic has anyone done a electric cooling fan conversion?
Hope this helps.
www.bigjimny.com/index.php/forum?view=to...id=7&id=54415#118026
2002 JLX Soft Top
Last edit: 23 Nov 2014 18:08 by dirtydogz.
- horam_jimny
24 Nov 2014 10:51 #130503
by horam_jimny
Replied by horam_jimny on topic has anyone done a electric cooling fan conversion?
I thought about one of these but decided against it for two main reasons.
If you forget to turn it off when entering deep water theres a good chance you'll knacker it as it struggles against the resistance of the water
More electrical stuff to go wrong especially if its getting submerged reguarly
The plus points of less resistance when driving normally so a possible increase in MPG would not off set the cost of it anyway.
The Jimny was designed to have the fan spinning constantly so you may find the engine temp fluctuates more as there will not always be that constant cooling effact which MAY cause issues.
- Reloaded
24 Nov 2014 11:32 - 24 Nov 2014 11:44 #130506
by Reloaded
Replied by Reloaded on topic has anyone done a electric cooling fan conversion?
I've got an electric fan on one of my Jimnys, it works a treat. There's no fluctuation in temperature, the engine warms up and stays constant no matter what. The one I have bolts on the engine-side of the radiator and pulls cold air through it.
Last edit: 24 Nov 2014 11:44 by Reloaded.
- S Mark
24 Nov 2014 18:57 #130535
by S Mark
Replied by S Mark on topic has anyone done a electric cooling fan conversion?
That's good to hear Mick C. I would need a engine side mounted one as well because I have a winch. I'm not really to bothered about mpg gains, I just don't like the way the viscous slows down the engine when wading.
- ATW1980
25 Nov 2014 19:36 #130629
by ATW1980
Replied by ATW1980 on topic has anyone done a electric cooling fan conversion?
I did it and i love it! Should have done it earlier!
More room for my winch up front!
Time to create page: 1.367 seconds
