Wheel spacers
- Lukeavb
22 Nov 2014 15:45 #130345
by Lukeavb
Wheel spacers was created by Lukeavb
My alloys were catching so ordered some 5mm wheel spacers just for the front two wheels, not much thread left to put the alloys wheel nut bolts i bought of ebay, so is there any longer bolts i can use for a safer length of thread to put my bolt onto?
thanks, luke.
thanks, luke.
- BigAndy
22 Nov 2014 16:53 #130348
by BigAndy
That's just got me thinking, will be alloy wheel nuts fasten up to steelies?
Replied by BigAndy on topic Wheel spacers
Lukeavb wrote: My alloys were catching so ordered some 5mm wheel spacers just for the front two wheels, not much thread left to put the alloys wheel nut bolts i bought of ebay, so is there any longer bolts i can use for a safer length of thread to put my bolt onto?
thanks, luke.
- Lukeavb
23 Nov 2014 00:06 #130382
by Lukeavb
Replied by Lukeavb on topic Wheel spacers
Yeah but the garage wouldn't change my tyres of my alloys over to steelies as they have 'cracks' in them
23 Nov 2014 06:48 #130383
by kirkynut
Replied by kirkynut on topic Wheel spacers
The thread is 12mm 1.25 pitch. There are plenty of long studs out there if you Google it. They are only just over a pound each. Order one and compare the splines to an original to check it will sit in the hub ok and if it does order more.
Or get offset wheels or a bigger spacer with its own studs built in.
- Lukeavb
23 Nov 2014 11:00 #130392
by Lukeavb
Don't fancy buying more spacers but what size would the long bolts be? Think I orderd the normal m12 alloy wheel nuts of eBay but couldn't find longer ones?
Cheers.
Cheers.
- NineCherries
23 Nov 2014 11:09 #130393
by NineCherries
Replied by NineCherries on topic Wheel spacers
Don't take this the wrong way but I think you might have gotten confused with what you are needing to order. The nuts stay the same. It's the 5x threaded studs (per wheel) that stick out at the hub after you take your wheel off that would be replaced with a longer version. Hope this helps.
Time to create page: 0.115 seconds
