Washing the clutch
  • rexthecat
17 Nov 2014 22:27 #129890 by rexthecat
Washing the clutch was created by rexthecat
Been having bitter bother with the clutch, clutch is new, cable was tight but didn't seem so tight to me when I looked to adjust it this eve, I slackened it off a bit anyhow and seem to move OK ( I had nearly no drive when I got home on Sunday) will try a bit of a test tomorrow night on the road, trouble is their london roads
I was going to wash the clutch before going out but just wanted to check what I'm doing....so basically it's more washing the shaft I guess as mud there would stop the clutch engaging / disengaging right? So do I need to get someone to press the pedal to wash behind the bearing. Also to wash where the thrust bearing will be pushing onto when pressing on the pressure plate do I sort of need to aim in through the pressure plate?
Is a normal hose on a strong jet OK to use?
I may have got the wrong end of the stick, just trying to work out how it all works.
Cheers
17 Nov 2014 23:26 #129903 by Johnniehec
Replied by Johnniehec on topic Washing the clutch
Personally I wouldn't be squirting water anywhere near the thrust bearing, I can only imagine it will lead to premature failure. I stand to be corrected but I don't think mud contamination can be the problem, have you seen the other post on clutch adjustment?
Cheers,
John.
17 Nov 2014 23:31 - 17 Nov 2014 23:34 #129904 by Johnniehec
Sorry Rex the cat I've just noticed the other post is yours Too!! 10 - 20mm free play, no tension at all.
Cheers
John.
Last edit: 17 Nov 2014 23:34 by Johnniehec.
  • rexthecat
17 Nov 2014 23:34 #129905 by rexthecat
Replied by rexthecat on topic Washing the clutch
Don't think I have, did a quick search but couldn't find much. Do you have any ideas what might be the cause? Cheers
  • rexthecat
17 Nov 2014 23:37 #129906 by rexthecat
Ahh ok ta, well I did slacken off a lot and that seemed ok with my very limited test. I guess 10mm free play at pedal end? Many thanks for the help
18 Nov 2014 08:22 - 18 Nov 2014 08:32 #129913 by kirkynut
Replied by kirkynut on topic Washing the clutch
I suspect you just need a new clutch.
If mud has got in there to that extent, it'll have worn it away like grinding paste. Just like it does to brake pads.
Having said that, there could be grit on the shaft that the release bearing runs on, stuck to it's grease, stopping it's movement.
Don't be squinting water in there though. You could get grease on the clutch.
Last edit: 18 Nov 2014 08:32 by kirkynut.
Time to create page: 0.111 seconds
