Just a thought.
  • Crumbley
02 Nov 2014 13:03 #128185 by Crumbley
Just a thought. was created by Crumbley
I have a year 2000 Jimny automatic.
I just had a thought that a buzzer like the one which tells you that you have left the lights on when the drivers door is opened would be rather useful if it would buzz if I I opened the drivers door when the transmission was not in park.
Is it possible? Has anybody done it?
02 Nov 2014 13:12 - 02 Nov 2014 13:16 #128186 by Jimbospanner
Replied by Jimbospanner on topic Just a thought.
Yes, I've done it.
Very easy, just need a 12 volt relay, buzzer, wire and some terminals.
How much more do you want to know? Conection between the relay and lights power?
I did mine on the ignition, not the door.
Last edit: 02 Nov 2014 13:16 by Jimbospanner.
  • Crumbley
02 Nov 2014 13:30 #128189 by Crumbley
Replied by Crumbley on topic Just a thought.
Thank you JimboSpanner.
Which automatic gearbox wire wire should I connect to?
Is it the position PRND display light or is there another way?
Sorry electrics isn't my strong point.
02 Nov 2014 14:22 #128195 by Jimbospanner
So,
I used the ign, independent to anything else as it was too hard to find any of the wires.
I used a light on the clock to power the buzzer, with the tap off the ign power ( cig lighter ) to power the relay.
Hope this pic helps.
  • Crumbley
02 Nov 2014 15:58 #128207 by Crumbley
Thank you, that is the level of detail I need.
Just one thing, I was looking have a buzzer when the automatic gearbox was not in the park position and the ignition was off or the drivers door was opened.
I've already got a buzzer for the lights being left on.
02 Nov 2014 17:41 #128221 by Jimbospanner
Oops my fault.
Same concept.
Time to create page: 0.224 seconds
