Jimny Hard Top to Soft Top conversion
- nuno
01 Nov 2014 12:35 - 01 Nov 2014 12:37 #128085
by nuno
Jimny Hard Top to Soft Top conversion was created by nuno
Hi,
I own a 2002 Jimny with an Hard Top ... it's great for the winter and to make longer trips, but in the summer I would prefer to use a soft top to easily remove it an get some sun
I searched around and got some results in JimnyBits , Monsoon and 4x4x4 .
Do you know if these can be mounted in my Jimny?
Do you have any experience with theses stores?
I'm in Portugal, so I would like to avoid returns and problems.
Just another question .. I see some references to MK1 and MK2. What are the diferences?
Thanks
Thanks
Last edit: 01 Nov 2014 12:37 by nuno.
01 Nov 2014 18:08 - 04 Nov 2014 18:48 #128116
by dirtydogz
2002 JLX Soft Top
Replied by dirtydogz on topic Jimny Hard Top to Soft Top conversion
Hi nuno.
I take it you have the hard top convection fitted to your soft top jimny from new as in the photo
If its yes, you will need to get the MK1 soft top kit, this will have the fitting kit which you will need so you can attach the back section to your jimny.
If you have the hard top on the front, you will need to get a second-hand frame kit to fit the front and back soft tops.
www.monsoon4x4.co.uk/images/Fitting%20In...ng%20Instruction.pdf
Use JIMNYBITS , Russ the owner of jimnybits is a member on this forum, or monsoon.
Hope is helps you.
DIRTYDOGZ
Hope is helps you.
DIRTYDOGZ
2002 JLX Soft Top
Last edit: 04 Nov 2014 18:48 by dirtydogz.
The following user(s) said Thank You: nuno
- idiotmobil
03 Nov 2014 19:21 #128369
by idiotmobil
Replied by idiotmobil on topic Jimny Hard Top to Soft Top conversion
- nuno
07 Dec 2014 17:58 - 07 Dec 2014 18:03 #131764
by nuno
Replied by nuno on topic Jimny Hard Top to Soft Top conversion
Hi,
My Jimny is an Hard Top from factory, so I don't think I can replace it with an Soft Top without the framework (told by Russ).
I notice 4x4x4 refers to a framework for 75:
www.4x4x4.com/accessories/suzuki/jimny_accessories_softtop1.htm
Should the framework and the soft top all that I need to replace my hard top in the summer?
Thanks
Thanks
Last edit: 07 Dec 2014 18:03 by nuno.
- RichiesJimny
07 Dec 2014 22:25 #131794
by RichiesJimny
Replied by RichiesJimny on topic Jimny Hard Top to Soft Top conversion
- nuno
08 Dec 2014 08:04 #131809
by nuno
Time to create page: 0.200 seconds
