Road orientated tyres
03 Nov 2014 15:41 #128336
by Busta
Replied by Busta on topic Road orientated tyres
Remember bigger tyres will put your odometer out so you need to factor in the % change in when calculating your MPG. The drop in economy with bigger tyres is always there, but it isn't quite as bad as the odometer makes out!
04 Nov 2014 22:16 #128517
by robs5230
standard jimny - for now
Replied by robs5230 on topic Road orientated tyres
i'm running 195 80 15's. my sat nav makes this size near as perfect for the speedo reading. i understand as standard the speedo reading will be slightly under actual speed. this will have an effect on mpgBusta wrote: Remember bigger tyres will put your odometer out so you need to factor in the % change in when calculating your MPG. The drop in economy with bigger tyres is always there, but it isn't quite as bad as the odometer makes out!
