indicators only right
- pcrepairmandan
07 Oct 2014 10:54 #125924
by pcrepairmandan
indicators only right was created by pcrepairmandan
when pressing the stalk for right the left indicator comes on.. any idea where to start looking ?
bulb looks ok and not blown
problems all started to occur since is first encounter with a lake
07 Oct 2014 11:11 #125926
by kirkynut
Replied by kirkynut on topic indicators only right
You are going to have all these electrical problems after how deep you dunked it. This is why insurance companies write off cars from flooding. Some you can never get to the bottom of.
Your best option is to put a de humidifier in the car for days with the doors all shut and hope for the best. If you haven't already done so you'll be chasing your tail as it's all still moist so earthing things that ought not be earthed etc.
- Docmartin4x4
07 Oct 2014 13:01 #125933
by Docmartin4x4
Replied by Docmartin4x4 on topic indicators only right
I'm afraid Kirkynut is oh so correct! I have dipped mine in a water/mud mixture.... well when I say dipped it was up to the windows on the outside and over the seats on the inside and I have had nothing but trouble ever since! leaving the car running with heater on full with windows slightly open has helped though. your indicator issue sounds a bit like the indicator relay, might be worth changing this.
Mart
Mart
- pcrepairmandan
07 Oct 2014 22:47 #125976
by pcrepairmandan
Replied by pcrepairmandan on topic indicators only right
It's got a de humidi in guys running but I wanted to go to work in it,
Where is the indicator relay located in the jimnys? I'll change it as a matter of precortion
08 Oct 2014 09:13 - 08 Oct 2014 09:15 #125985
by kirkynut
Is it with the fuses under the dash on drivers side?
They'll be a couple but you'll hear it click when you turn them on.
I'm a little unsure how much is controlled by either the ecu or a separate body control module as I've never had to worry.
Last edit: 08 Oct 2014 09:15 by kirkynut.
- pcrepairmandan
08 Oct 2014 11:13 #125995
by pcrepairmandan
thank you dude
ive seen one but ill get looking some more! WHEN i cure it... maybe if it takes a year ill wrap the bastard up in leccy tape
Time to create page: 0.107 seconds
