Difficult to start, then lots of white smoke
28 Sep 2014 19:46 #125313
by facade
Replied by facade on topic Difficult to start, then lots of white smoke
Jaguar XJ8 V8s are renowned for it, and it takes 2 hours to change the 'plugs if you can't start it by keeping the pedal flat (which puts it in "no fuel" mode) to clear the engine.
28 Sep 2014 19:48 #125315
by Rhinoman
Replied by Rhinoman on topic Difficult to start, then lots of white smoke
I would do a compression test.
29 Sep 2014 06:22 #125344
by Elaine
Aaah, never owned a Jag. They're not a make that appeals to me... I prefer relatively rare sporty cars.
Replied by Elaine on topic Difficult to start, then lots of white smoke
facade wrote: Jaguar XJ8 V8s are renowned for it, and it takes 2 hours to change the 'plugs if you can't start it by keeping the pedal flat (which puts it in "no fuel" mode) to clear the engine.
29 Sep 2014 09:43 #125353
by kirkynut
Replied by kirkynut on topic Difficult to start, then lots of white smoke
Jimnys do have a problem sometimes if they are started and quickly stopped then re started. At which point they can want to not start.
I think over fuelling where fuel is still injected after shut down is the issue. So the plugs are wet. Wide open throttle gives more air and balances the over fuelling.
Mine has done it a number of times but not lately. I am conscious of it though so let it run for a while. I have a clip to connect my garage keys to the ignition key to be able to separate them and lock the garage with it running.
I've not had a problem the day after though.
I would run it as normal locally and keep an eye on it with regards to oil and coolant levels and oil in the coolant or vice versa and maybe change the spark plugs unless you know they're newish.
It could be spark plugs on the way out.
If it persist and there is no obvious cause I'd start to investigate further. A compression test then perhaps coolant temperature sensor replacement and throttle body / air flow meter clean.
I think it's just one of those quirks though in all honesty.
The following user(s) said Thank You: 2013gary
- 2013gary
29 Sep 2014 14:36 #125384
by 2013gary
Replied by 2013gary on topic Difficult to start, then lots of white smoke
I took it for a 5 mile drive yesterday and all seemed fine. It started fine again this morning and drove a further 20 miles with no visible smoke or anything.
I think kirkynut may be right though as I did start it for only a few seconds the day before, which is something that I never normally do. Now that I am aware I will probably never do it again. If it wasn't for that smokey start up then everything would be normal so I'll just carry on as normal but keep an eye on the levels. Thanks again for the advice though.
- Basketcase
- Thank you received: 51
29 Sep 2014 17:18 #125397
by Basketcase
Replied by Basketcase on topic Difficult to start, then lots of white smoke
Ours does it if we start it and stall it taking it off the drive or something takes a bit for it to realise we want it running again. Few good revs and it clears up alright
Time to create page: 0.493 seconds
