fitting front fogs
- Whaley
16 Sep 2014 15:53 - 16 Sep 2014 15:55 #124281
by Whaley
fitting front fogs was created by Whaley
Hello i am trying to fit fog lights on my 03 model i have bought a switch oe from ebay, i notice under the bonnet there are two small plugsccoiled up next to the headlights one either side and one other plug 5 pin in front of the air box are these anything to do with fogs ? The light comes on when the button is pressed do i need a relay if so where does it fit ? I can't see anything in the hand book relating to relays ??
Last edit: 16 Sep 2014 15:55 by Whaley. Reason: spelling error
- Basketcase
16 Sep 2014 16:38 #124285
by Basketcase
Replied by Basketcase on topic fitting front fogs
Think it's the little white plug, try a spot lamp just in that and press the button on dash to check
- Whaley
16 Sep 2014 18:12 #124295
by Whaley
Replied by Whaley on topic fitting front fogs
Thanks ive checked for voltage on that plug and there doesn't seam to be any, them plugs are on both sides thats why i thought they were fog light wires do you know if there is a relay sspecifically for front fogs ?
- Basketcase
16 Sep 2014 20:46 #124324
by Basketcase
Might just be easier to wire them on a seperate circuit. Get a wiring kit off ebay or halfords and use that but you need 2 power supplies to the relay the switch from lights on the jimnys is negative and just connect it to your side light circuit
16 Sep 2014 22:25 #124333
Did you check with sidelights on?
I can look tomorrow and see what's what.
Replied by helijohn on topic fitting front fogs
Whaley wrote: Thanks ive checked for voltage on that plug and there doesn't seam to be any, them plugs are on both sides
- Whaley
17 Sep 2014 06:02 #124338
by Whaley
I think so, I will check again tomorrow after work
Time to create page: 0.108 seconds
