MOT and ARB removal
- Basketcase
- Thank you received: 51
07 Sep 2014 08:04 #123510
by Basketcase
Replied by Basketcase on topic MOT and ARB removal
As long as you remove the ARB and the bushes/brackets for it it'll pass if you remove the ARB but leave a bush on the car technically it should fail
The following user(s) said Thank You: GuardianAngel
- RichiesJimny
07 Sep 2014 09:15 #123518
by RichiesJimny
Replied by RichiesJimny on topic MOT and ARB removal
www.motinfo.gov.uk/htdocs/m4s02000408.htm
It tells you there if a component missing where one is know to be fitted as standard is a failure, so yes it should fail if the tester is familiar with jimny's but in reality most mot testers will pass it but it's no good kicking off with the tester if he fails it because he is right to do so.
- GuardianAngel
07 Sep 2014 12:18 #123529
by GuardianAngel
I have no intention with arguing with him if he does
Replied by GuardianAngel on topic MOT and ARB removal
RichiesJimny wrote: www.motinfo.gov.uk/htdocs/m4s02000408.htm
07 Sep 2014 12:22 #123531
by kirkynut
Replied by kirkynut on topic MOT and ARB removal
I would just make it look as much like it was never there as possible and hope for the best!
It'll be fine!
It'll be fine!
08 Sep 2014 08:39 #123598
by Busta
Replied by Busta on topic MOT and ARB removal
I've been running mine with just 1 drop link removed for 6 months now. It has the same handling/articulation benefits as removing the ARB completely, but come MOT time I can put the drop link back on in 5 minutes and be sure it won't be a problem.
- Leathery1
08 Sep 2014 22:30 #123665
by Leathery1
Replied by Leathery1 on topic MOT and ARB removal
2 MOTs with it missing, but both done by the garage which has done most of my mods for me, so no problems there. Find a 4x4 savvy tester and they wont expect you to keep it on.
A little more body roll on fast corners once its off, but Jimnys aint hot hatches! And much better articulation.
Time to create page: 0.246 seconds
