Fixing bump steer
  • Shep
08 Aug 2014 22:43 #121587 by Shep
Fixing bump steer was created by Shep
How do I lower the panhard and steering arm angles to remove/reduce bump steer?
Is there a drop pitman arm available?
  • TomDK
09 Aug 2014 00:43 #121593 by TomDK
Replied by TomDK on topic Fixing bump steer
Do you experience problems with bump steer?
I know some jimny owners put brackets and stuff on to fix bump steer. Bump have never actually read about anyone experiencing it.
  • Shep
09 Aug 2014 02:05 #121594 by Shep
Replied by Shep on topic Fixing bump steer
Yep I have bump steer. It is caused by the pitman and steering arm angles being to steep.
  • g r e e n
09 Aug 2014 14:22 #121625 by g r e e n
Replied by g r e e n on topic Fixing bump steer
You could just over turn steering rod from bottom to top. For such mod you need one steering rod end of Mitsubishi Pajero or L200. It has same thread pattern as Jimny's rod ends and bigger cone part. Also you need to modify a bit your left steering knuckle (for RHD and right knuckle for LHD). You need to cut hole for MMC rod end in opposite direction.
Look at photo and you will see.
Both rods are perfectly parallel and almost at level. This Jimny has 4" suspension lift.
  • Nicks_Jim
09 Aug 2014 15:09 - 09 Aug 2014 15:15 #121629 by Nicks_Jim
Replied by Nicks_Jim on topic Fixing bump steer
Last edit: 09 Aug 2014 15:15 by Nicks_Jim. Reason: incorrect link
  • Shep
09 Aug 2014 23:04 #121663 by Shep
Thanks Nicks_jim. The panhard is easy enough to lower however lowering the steering rod and staying road legal is a bit trickier. On my old sierra(samurai) I just used a dropped pitman arm and am hoping that there is one available for a jimny.
Green, that is the result I am after. Nice flat arms, that thing would drive like stock however I can't use the same method to lower the steering arm.
Time to create page: 0.110 seconds
