2014 Mods help.
  • Brave
30 Jul 2014 05:03 - 30 Jul 2014 05:08 #120994 by Brave
2014 Mods help. was created by Brave
First things first, Hello all, first post so go easy.
Ok so i'm new the Jimny world, have just got my car she is a 2014 1.3 (non VVT, non ABS and non airbag) model.
I have already started modding, I've given her a 2"ironman suspension lift and fitted some 235/75/15 GT radial saveros on, the fit is good with only minor rubbing on the front bumper, nothing that a Stanley didn't fix.
I have noticed a change in the performance after fitting the bigger tires but nothing to drastic, just feels like she's full. Also i have come from the world of diesel so any petrol feels like you have to work the box far too much :) .
On a side note how great would this car be with a modern HDi in it. :woohoo:
Ok i know your gona ask why didn't i just fit smaller tires, the problem is here (Brunei) this is the smallest tire i can get with out shipping them in.
Next im looking at fitting a snorkel and maybe changing the transfer box, or just gona do some small mods to the engine. This is what i'm where I'm after some advice. What are my options. Also if any of you have trimmed your bumper what lines did you go for.
Oh yes this is gona be my daily use car, its only maybe a 50km round trip for work and for getting around Brunei, lots of sweet jungle trails and not so sweet nasty roads, the max speed here is 100km and most of the time I'm just doing 60.
I intend to be doing lots of off-roading and am not worried about any level of maintenance required. Though I don't really want to brake stuff unnecessarily getting parts here can be a issue.
Thanks for all your help
Last edit: 30 Jul 2014 05:08 by Brave. Reason: Spelling
30 Jul 2014 12:41 - 31 Jul 2014 14:07 #121027 by kirkynut
Replied by kirkynut on topic 2014 Mods help.
Hi there and welcome!
You are BRAVE modding a brand new Jimny!
I can't help with bumper cutting as I replaced mine with Heavy Duty Steel ones rather than mess about cutting plastic ones.
Gearing wise it may be easier to get gear reduction gears for your transfer box but the chain in the Jimny transfer boxes stretches over time, especially with more torque from reduction gears.
It is possible but harder work to fit a rocklobster I believe, I don't know so much about the brand new ones and if they are the same as the VVT 2006 on models over here or not. I think Zukenutter on here and Auszookers has done the conversion, so look in My Jimny or The Rigs of Auszookers : www.bigjimny.com/index.php/forum?view=topic&catid=8&id=2047 & auszookers.com/forum/viewtopic.php?f=4&t=16751 - you have to sign up to Auszookers to see that.
I'm not a diesel man so I like the Jimny petrol, but a bigger petrol conversion would be cool - again as Zukenutter has done.
Snorkels are easy to come by.
You are lucky to get new models over there without Airbags and ABS! If they did them here I'd consider one!
Pictures would be good mate!
Last edit: 31 Jul 2014 14:07 by mlines.
  • Brave
30 Jul 2014 13:36 - 30 Jul 2014 13:49 #121029 by Brave
Replied by Brave on topic 2014 Mods help.
Hi Kirkynut and thank you for the welcome,
Stock tires
Proper tires :)
Yep I've done a bit of googling and think the quickest and easiest way would be to fit the auto transfer case. But i think I'm just gonna run it and see how she goes.
Last edit: 30 Jul 2014 13:49 by Brave.
  • Jimny_Aus
30 Jul 2014 23:35 #121096 by Jimny_Aus
Replied by Jimny_Aus on topic 2014 Mods help.
how does it feel on the clutch with 30's do you have to ride it a little??
  • Brave
31 Jul 2014 03:25 - 31 Jul 2014 14:07 #121098 by Brave
Not really, the car just feels full.
The biggest thing is the car feels more slugish, and you have to use a little more first, but once the revs are up she goes good.
I have found that off road it is a harsher I do ride it more though but only in 4x4h in low i can happily pull off with no gas, and in 2 i have no problems braking the back end out(not much different than before though).
I think 215's would have been the sweet spot, but with the cost of the tire shipping and import duty they would have cost way too much. As it is the tire i have cost me 145 bnd (apx 70 quid) a corner (tires, oil and fuel dirt cheep here, i won't tell you the price of fuel you'll puke). Also most the off road here is boggy clay so I hope the 235's will help, as i've been told by the guys here.
The money i've saved can pay for a couple of quick engine upgrades to off set the power loss a K&N filter and a better exhaust system to give a couple more horse. Dam i think the money I save could even pay for the gears.
  • Brave
31 Jul 2014 03:27 #121099 by Brave
Just a quick one what pressure are you guys running the bigger tires at? are you using tire pressure charts to convert the pressures across?
Time to create page: 0.099 seconds
