Convert push button to stick shift transfer box
  • Docmartin4x4
19 Jul 2014 21:52 #120333 by Docmartin4x4
Hi all, I have a 06 VVT with push button transfer box and 4 WD.
Is it easy enough to convert to stick shift?
I want to get an auto transfer box as they have a lower ratio, but can I fit an earlier auto transfer box (stick shift), will I need to change any propshafts?
Mart
  • Jutwit
20 Jul 2014 09:43 - 20 Jul 2014 09:44 #120349 by Jutwit
I asked a very similar question a while back but wanted to put in a rock lobster got in touch with rob storr and this is what he said
they can be fitted but you would need to modify your middle prop shaft length and remove the blanking plate from the tunnel. It would be very low geared as the ratios are different in the gearbox on the vvt but you could fit an early gearbox with an adapter plate. Its all do able just a bit more involved with the vvt
Hope that's of some use
Last edit: 20 Jul 2014 09:44 by Jutwit.
20 Jul 2014 10:30 #120351 by Obarno
I have a 2007 VVT with rocklobster transfer box. The box was fitted when I bought the car but it was very low geared as the VVT gearbox has lower ratios than the up 2005 m13 gearbox. Crucially it's 5th gear which is noticeably low as it's a 1:1 gear rather than about .75 which the earlier box has. I have fitted 30" tyres and also changed the diffs to 3.9 rather than 4.3 but even so it's low geared on the main roads. However off road it's good as it has plenty of low gears and seldom runs out of puff!
The centre prop for the VVT is different as the gearbox spline is different, but if you fit a rocklobster you have to shorten the centre prop anyway, or fit a Samurai prop. It's easy then to change the gearbox spline joint for the VVT one on the Samurai prop. As regards the gear lever there is a removable plate in the tunnel and you can then use a Samurai gaiter and retaining plate. For the dashboard 4x4 light you can wire the rocklobster switch to which ever one of the lights you prefer, either the high range or low range. The Samurai switch will earth the wire to the dashboard light and it works. Unfortunately I don't now remember the wire colour but you could find it from a wiring diagram. I joined the wire by the module above the accelerator pedal. If yours has aircon by cutting the original wiring 4x4 light wire you will overcome the aircon not working in 4wd.
Don't know if this helps or confuses but good luck.
The following user(s) said Thank You: Docmartin4x4
21 Jul 2014 21:21 #120449 by Busta
The non-electric transfer boxes all had the same ratios. They are lower than your electric transfer box, but not as low as the automatic electric transfer boxes.
www.bigjimny.com/images/documents/transferboxratios.pdf
  • RichiesJimny
21 Jul 2014 21:38 #120452 by RichiesJimny
Replied by RichiesJimny on topic Convert push button to stick shift transfer box
It could work out cheaper to fit a trailgear reduction kit in your existing transfer box than it would be to the convert it to a stick shift or rocklobster.
  • Jutwit
21 Jul 2014 22:23 #120455 by Jutwit
Is it possible to put a lever on an electric transfer box then?
Time to create page: 0.107 seconds
