Steering wobble - 2009 advice please.
- Caulkheader
28 Oct 2010 14:44 #5465
by Caulkheader
Steering wobble - 2009 advice please. was created by Caulkheader
Hi -
I have had my 2009 Jimny for three weeks now. When I test drove the car I identified the 45mph steering wobble. The dealer assured me that it could be cured. (Main dealer / Suzuki warranty)
Its now due to go back a third time. Its had the King Pins and arms shimmed together with new discs and a five stud wheel balance. The problem is now significantly worse.
I am getting to the point that I am considering rejecting the vehicle.
The dealer is, I think, running out of ideas. I have read the threads on here and other OC sites about the problem but they don't seem to say the problem is permanently cured.
Is it possible to cure this or is it something you have to learn to live with? I love the car and its simplicity but I cant live with the problem, if its curable I will let them keep trying.
John
John
- leswilluk
28 Oct 2010 17:05 #5473
by leswilluk
Replied by leswilluk on topic Re: Steering wobble - 2009 advice please.
I have a 2009 Jimny which I bought new which sometimes had a bit of a wobble when rapidly slowing from speed say 60 mph or so, when it had its first service I asked the dealer to look at it, they had a couple of technical print outs which I managed to get a sly look at, one was to shim the king pins the other was to replace the leading arm bushes, they decided that in my case replacing the bushes in the leading arms was the way to go, it has by and large fixed it but if the speed, road conditions etc conspire the right way I can still sometimes notice a slight touch of wobble.
- Caulkheader
28 Oct 2010 18:15 #5478
by Caulkheader
Replied by Caulkheader on topic Re: Steering wobble - 2009 advice please.
Thanks for the reply, at the moment mine is now much worse and bordering on the un drivable..
John
John
29 Oct 2010 15:59 #5503
by kirkynut
Replied by kirkynut on topic Re: Steering wobble - 2009 advice please.
A change in wheel bearing fixed it for me, but your car is only a year old and can't have done many miles has it?
- g187eev
31 Oct 2010 22:55 #5617
by g187eev
Replied by g187eev on topic Re: Steering wobble - 2009 advice please.
The Jimny steering wobble is an utter phenomena in most cases...
Even though it must be happening for a good reason... the fittment of a good quality steering damper kit will cure it in 95% of cases.
Rob
Rob
- Caulkheader
01 Nov 2010 12:58 #5628
by Caulkheader
I have read that but am loath to do that on a car that is still under warranty ?
John
John
