Adjusting handbrake
- rexthecat
06 Jul 2014 07:06 #119369
by rexthecat
Adjusting handbrake was created by rexthecat
Hi folks, my handbrake could do with a bit less free play in it, I don't think the shoes are worn or need adjusting as stops fine. Is there an adjuster on the hand brake lever?
Someone mentioned a hole in the back of the rear brakes to access the adjuster there had a quick look but couldn't see it. Its a 99 g13b
Cheers
Cheers
- Gjmcleod
06 Jul 2014 10:45 - 06 Jul 2014 11:09 #119384
by Gjmcleod
Replied by Gjmcleod on topic Adjusting handbrake
If you remove the plastic cover around the hand break lever , their is an adjuster on the cable , you need a 10mm deep socket ,,,, at the rear , backing plate , their is an oval rubber gromit at each side , pop that out & use a flat screwdriver to adjust the free play between the shoes & the drums ,,,,,, loosen off adjustment @ handbrake , then adjust shoes. @ rear , them take up tension at handbreak again ,,,, I find it Easyer to do with both back wheels off & up in axle stands
. Need to be carefull not to over tighten at the rear , or you have to strip the drums off to loosen it off again ;(
Last edit: 06 Jul 2014 11:09 by Gjmcleod. Reason: Add picture
06 Jul 2014 13:14 #119390
by Rhinoman
Replied by Rhinoman on topic Adjusting handbrake
I would check the shoes first, even if it does seem to stop OK.
06 Jul 2014 21:09 #119415
by kirkynut
Replied by kirkynut on topic Adjusting handbrake
Yes, check the shoes and their adjustment and that the self adjusting mechanism is working and not seized. Otherwise you will be treating the symptom not the cause!
- Gjmcleod
06 Jul 2014 22:01 #119436
by Gjmcleod
Where is the self adjuster ? I always seem to have to adjust mine manually , just in case I am missing something too ?? Cheers
06 Jul 2014 22:42 #119444
Replied by helijohn on topic Adjusting handbrake
Are we talking slop in the cable cos the adjuster for that on mine is at the back end of the H/B lever.
Time to create page: 0.116 seconds
