Removing diff plug
  • rexthecat
12 years 4 months ago #118303 by rexthecat
Removing diff plug was created by rexthecat
Been a bit daft, tried to use a 3/8 drive to try and remove the plug, rounded it a bit. Any ideas how to 1 remove it, 2 where I can get a new one?
Cheers
12 years 4 months ago #118308 by Busta
Replied by Busta on topic Removing diff plug
If you have access to a welder, weld something to it that you can get an adjustable spanner on. The heat of the welding will loosen it a bit too.
If you don't have a welder, you need to make or find something that is a good fit (hammer in an allen key/trx bit) and maybe heat it up a bit too.
You can get a new plug from a Suzuki dealer.
12 years 4 months ago #118309 by j999pre
Replied by j999pre on topic Removing diff plug
The fill plug or drain plug? Fill plug can be knocked round with a chisel
Grey pick up Jimny
  • benny
12 years 4 months ago #118316 by benny
Replied by benny on topic Removing diff plug
I could not get the fill plug out of the rear diff. so I got a nut and then welded it to the fill plug so you can get a socket on to it good luck. :)
  • Ryan270990
12 years 4 months ago #118322 by Ryan270990
Replied by Ryan270990 on topic Removing diff plug
the best way is to knock a allen key socket into the plug. it wont be that tight that you need to apply heat or weld a nut to it. the shock of the hammer blow will loosen it. knock the socket in and keep it straight in the plug when loosening it off. try and get 1/2 strong bar to achieve the leverage.
  • helijohn
12 years 4 months ago #118345 by helijohn
Replied by helijohn on topic Removing diff plug
Yes I often use an air impact wrench or heat. I dunno why they are often so tight but even the regular bolts are really whacked up from the factory.
