Rear Brake Load Adjuster Question
  • Adamski
  • Visitor
  • Visitor
27 Oct 2010 19:34 #5427 by Adamski
Rear Brake Load Adjuster Question was created by Adamski
Following a suspension lift on your Jimny has anyone altered their rear brake load adjuster. I've read that when the the Jimny has weight in the back it adjusts the rear brakes so that they do more work. Working on logic, now that mine is 3" higher, it must think that there is never any weight in the back and therefore the rear brakes are doing little, if no work?
My brakes seem pretty good, however I'd like to know that both the front and rear brakes are doing their bit to give the best stopping power possible.
  • darthloachie
  • Visitor
  • Visitor
27 Oct 2010 19:37 #5429 by darthloachie
Replied by darthloachie on topic Re: Rear Brake Load Adjuster Question
It doesn't get any lighter because it is higher so you will still have the same weight distribution - tyres will have more impact on stopping distances
  • Adamski
  • Visitor
  • Visitor
27 Oct 2010 19:43 #5430 by Adamski
Replied by Adamski on topic Re: Rear Brake Load Adjuster Question
darthloachie wrote: It doesn't get any lighter because it is higher so you will still have the same weight distribution - tyres will have more impact on stopping distances
My thinking is that now the axle is further away from the chassis, the adjuster spring is now stretched which must 'fool' the adjusted in thinking that the rear brakes arent requires as much so reduced the power of them. Then when I put stuff in the back or have a trailer on, due to the lift, the adjuster spring is still going to be stretched (unless the weight compresses the springs by 3"+ , which would probably take a hell of a lot of weight).
28 Oct 2010 05:44 #5443 by mlines
You are correct. The adjuster is designed to adjust the braking power to the rear depending on the load in the Jimny and the way it does this is based on the tension in the spring. You will see that the Trail Master Kit in the store has an additional bracket to put the adjuster back into its normal position after a lift.
However there is some adjustment in the mounting point as standard and the bracket in the kit is only a piece of metal so I am sure you can sort something out.
  • darthloachie
  • Visitor
  • Visitor
28 Oct 2010 07:36 #5445 by darthloachie
doh! how thick am I - knew Martin would have the answer
28 Oct 2010 13:47 #5463 by Obarno
Funnily enough I have just altered the bracket on mine for the very reason the back brakes aren't doing much. Last time it was MOT'd they didn't do much at all. I have a 3" lift so I have extended the spring bracket by 3" so the spring is not now under any tension and pushes the leaver on the valve back to where it was. Not sure it makes much difference but makes me think it should!
  • Adamski
  • Visitor
  • Visitor
28 Oct 2010 16:22 #5467 by Adamski
Obarno wrote: Funnily enough I have just altered the bracket on mine for the very reason the back brakes aren't doing much. Last time it was MOT'd they didn't do much at all. I have a 3" lift so I have extended the spring bracket by 3" so the spring is not now under any tension and pushes the leaver on the valve back to where it was. Not sure it makes much difference but makes me think it should!
Thanks for the info all :) . Obarno, Do you have any photos of the bracket? I think I will fabricate one this weekend and would be great to see one already done and fitted.
Cheers,
Adam
29 Oct 2010 12:44 #5488 by Obarno
Hi Adam - its very simple really just a piece of 4mm strip with a hole at each end 3 inches apart. The bottom hole is offset slightly so that the strip locates against the lip on the original bracket. It seems perfectly strong. The part the spring fits on to unbolts. I have attached a couple of pics - if I had known when I made it that it was going to be photo'd I would have painted it!
Have fun - Peter
The following user(s) said Thank You: Adamski
  • Adamski
  • Visitor
  • Visitor
29 Oct 2010 15:35 #5499 by Adamski
Obarno wrote: Hi Adam - its very simple really just a piece of 4mm strip with a hole at each end 3 inches apart. The bottom hole is offset slightly so that the strip locates against the lip on the original bracket. It seems perfectly strong. The part the spring fits on to unbolts. I have attached a couple of pics - if I had known when I made it that it was going to be photo'd I would have painted it!
Have fun - Peter
Thanks for the photos Peter! Looks very straight forward so I think I'll make one this weekend :). Did you notice your braking power increase after you fitted it?
Cheers,
Adam
30 Oct 2010 14:46 #5550 by Obarno
Hi Adam - I noticed two things after fiting it - the brake performance was definitely better and also the pedal felt better too - a bit firmer. Hope it works ok for yours - Peter
  • Adamski
  • Visitor
  • Visitor
31 Oct 2010 14:34 - 31 Oct 2010 14:37 #5592 by Adamski
I've made my bracket which was very straight forward and have noticed 2 things:
1) My brakes are better
2) My Steering wobble has reduced significantly :cheer: :cheer: :cheer:!!
I haven't got a clue why doing something to the rear brakes would reduce the wobble, it is most probably just a coincidence but it is now much better to drive :cheer: .
I' also fitted a Klaxon (argh oogh aaa) horn B)
Thanks for the all the info and photos Peter!!
Last edit: 31 Oct 2010 14:37 by Adamski.
  • Reloaded
  • Visitor
  • Visitor
31 Oct 2010 14:52 #5593 by Reloaded
Replied by Reloaded on topic Re: Rear Brake Load Adjuster Question
Well done on the wobble!!! Luckily I've never experienced it (touches huge piece of timber B) )
Can't wait to hear that Klaxon
Time to create page: 0.315 seconds
