Lockrite
  • Bigchridy
27 Oct 2010 19:26 #5425 by Bigchridy
Lockrite was created by Bigchridy
Has anyone fitted a lockrite diff lock to either front or rear or both diffs on their Jimny? I have been looking at these on youtube and they look like a good bit of kit. I would ideally be after a Kam diff lock but these are quite expensive!
If anyone has had any experiances with lockrite diff locks any info would be appreciated. Also any pics of fitting a lockrite would be helpful.
Cheers
Chris
  • darthloachie
27 Oct 2010 19:34 #5428 by darthloachie
Replied by darthloachie on topic Re: Lockrite
Hi
Don't have any photos of fitting but I do have a lockrite fitted to the rear axle.
It is pretty effective piece of kit It is only occasionally I need to use the front ARB and can get up hills that some l*ndr*v*rs get stuck on :cheer:
Its also pretty tough as it has been fitted for quite a few years.
It is automatic so no need to switch any thing on but you can fell it pushing the truck straight on some times when you are doing a tight turn on very slippery mud
  • Bigchridy
27 Oct 2010 20:02 #5434 by Bigchridy
Replied by Bigchridy on topic Re: Lockrite
darthloachie wrote: Hi
How come you have an arb on the front? Can you fit lockrites to the front axle? I will be buying the rear locker 1st to try and keep costs down but I will be getting a front one eventually!! From what you have said I take it I'll get away with just a rear locker for a while?:cheer:
  • darthloachie
27 Oct 2010 20:08 #5435 by darthloachie
I'll have to pass on that question as when we bought the truck it came with a lockrite on the rear and the ARB on the front - they were fitted by different owners - the arb when it was used for winch trials
27 Oct 2010 20:28 #5438 by kirkynut
Replied by kirkynut on topic Re: Lockrite
What's the lockrite like on the road?
28 Oct 2010 05:39 #5442 by mlines
Replied by mlines on topic Re: Lockrite
The key difference between a Lockrite style locker and a KAM/ARB style locker is the way they operate.
A Lockrite locker is always locked, until the pressure causes it to unlock and release wind up. Therefore as you corner with it you can feel it unlocking and can hear it, varying from a "click" on a well set up one through to a banging on a poorly set up one. This means you always know its there and have to adopt your driving style a bit.
ARB/KAM lockers are manually controlled through Air or Electric operation. This means you can decide when select them or not. This has an advantage for on-road driving where you can select them off and not know they are there. Equally you can also switch them off when off-roading when a locked diff can cause you more issues than it prevents. For example, on a site I go to there are a number of chalk slopes which are like ice when wet. As you climb them you do not want the front of the car to start slipping around sideways leaving you across the slope! With a rear locker fitted both my back wheels are nicely driven meaning that it spins both rear wheels on the slippery slope which makes the rear of the Jimny snake around, forcing the front to start slipping sideways (gulp). Therefore on this site I often have the locker off to make the rear stay in line with the front.
Having driven both I would always go for ARM/KAM style if you can afford them. Lockrites are cheaper but can mean you lose everyday drivability.
Time to create page: 0.333 seconds
