Lo box not working
- Jutwit
18 May 2014 21:10 #115656
by Jutwit
Lo box not working was created by Jutwit
Lo box would not engage today at all, just flashing light and beeping, I tried going back a bit etc but it just wouldn't play ball, any ideas? I haven't looked at it at all yet cos just got in, and I've got the push button selector
- Bits4Vits
18 May 2014 21:47 #115664
by Bits4Vits
Replied by Bits4Vits on topic Lo box not working
Not sure if it's like my New Grand Vitara? With the selector on that the ECU detects whether you've got the brake and clutch pedal pressed down before it will let you go into four-low, otherwise it just beeps and refuses to let you...
- Jutwit
19 May 2014 07:34 #115688
by Jutwit
Replied by Jutwit on topic Lo box not working
Just tried it and it's working fine
it only goes in with the clutch pressed, doesn't matter if I press the brake or not or if it's in gear, pretty sure I was pressing the clutch yesterday, where is the ecu located ? Will water affect it? Went through some big puddles yesterday
- jonesyba420
19 May 2014 07:53 #115690
by jonesyba420
Replied by jonesyba420 on topic Lo box not working
Believe the ecu is in the main cab.
- Bits4Vits
19 May 2014 08:41 - 19 May 2014 08:50 #115698
by Bits4Vits
That's probably it, the clutch needs to be pressed down before the ECU will let you select four-low... I much prefer a stick you can ram in!!
Spotted my ECU up under the dash by the passenger door hinges... quite high, your bum will be wet before it gets wet!
Last edit: 19 May 2014 08:50 by Bits4Vits.
- Jutwit
19 May 2014 08:50 #115700
by Jutwit
Hmmm just have to wait and see what happens next time then, thanks guys
Time to create page: 0.109 seconds
