Gearbox reverse light switch - how to remove!
  • GuardianAngel
28 Dec 2013 14:58 #97816 by GuardianAngel
Gearbox reverse light switch - how to remove! was created by GuardianAngel
I am in the process of trying to remove all the gubbins to change my clutch (M13A/manual gearbox). The BJ clutch guide states that the reverse light switch plug needs to be removed, but I can't determine if you just pull it out or whether you need to undo the nut that goes into the housing. I have tried pulling but that does not work :laugh:
If you do need to undo the nut, any ideas on the nut size as none of my spanners fit :angry:
  • gus2000
28 Dec 2013 15:09 #97818 by gus2000
Replied by gus2000 on topic Gearbox reverse light switch - how to remove!
Hello, in the end of wire has a plug, which is at the top of the flywheel cover
Cheers
Gustavo
  • GuardianAngel
28 Dec 2013 17:01 #97838 by GuardianAngel
Replied by GuardianAngel on topic Gearbox reverse light switch - how to remove!
Many thanks. Do you know the size of the nut?
  • markyp2000
28 Dec 2013 17:05 #97841 by markyp2000
Replied by markyp2000 on topic Gearbox reverse light switch - how to remove!
Unplug it as when you turn it it will twist the wires and may brake
  • helijohn
28 Dec 2013 18:19 #97871 by helijohn
Replied by helijohn on topic Gearbox reverse light switch - how to remove!
GuardianAngel wrote: Many thanks. Do you know the size of the nut?
Looks liike 22 or 24mm? Can you not use and adjustable wrench?
  • GuardianAngel
28 Dec 2013 18:22 #97873 by GuardianAngel
Tried that but they are crap. They dont stay in a set position and open up as I start to turn, increasing the chances of rounding off the nut.
