How can i check the gearbox oil level ?
- ACE
18 Dec 2013 11:34 - 18 Dec 2013 11:36 #96647
by ACE
How can i check the gearbox oil level ? was created by ACE
Hi guys,
I want to know if there's a way to check my gearbox oil level ? and if i can add to it ?
Last edit: 18 Dec 2013 11:36 by ACE. Reason: wrong topic
- Thank you received: 1854
18 Dec 2013 12:25 #96652
Replied by Lambert on topic How can i check the gearbox oil level ?
Most gearboxes are full when oil drips from the fill hole on the side. I have not yet looked for mine so can't say where you will find it.
- GuardianAngel
18 Dec 2013 12:33 #96653
by GuardianAngel
Replied by GuardianAngel on topic How can i check the gearbox oil level ?
This guide on changing the clutch has a picture of where to find the filler and drain plug for the gearbox.
www.bigjimny.com/images/documents/Changing_the_Clutch.pdf
- Reloaded
18 Dec 2013 12:55 #96654
by Reloaded
Replied by Reloaded on topic How can i check the gearbox oil level ?
No eBay APP ID and/or Cert ID defined in Kunena configurationIf you need to top it up the filler is a bit of a bitch to get to, you'll need some sort of pump with a flexi pipe to get to it. I use one of these (below) - it's not brilliant but it works
- markyp2000
18 Dec 2013 13:14 #96658
by markyp2000
Replied by markyp2000 on topic How can i check the gearbox oil level ?
Drivers side half way up you should see a square plug size of a 3/8 rachet undo it and stik ya little finger in and bent it down if it need topping up use a funnel and a bit of hose pipe fed in from the engine bay and top it up slowly
- JivingDaddy
18 Dec 2013 15:45 #96663
by JivingDaddy
Replied by JivingDaddy on topic How can i check the gearbox oil level ?
Good luck undoing the filler plug. They can be a right female dog!
Time to create page: 5.812 seconds
