4wd light blinking
- tenchangle
12 years 11 months ago #96438
by tenchangle
4wd light blinking was created by tenchangle
I have a problem with the 4wd light blinking it does not stay on when i engage 4wd so i dont know if its actually in gear or not any advice would be grateful cheers pete
- jonesyba420
12 years 11 months ago #96439
by jonesyba420
Replied by jonesyba420 on topic 4wd light blinking
Most likely a leak in the vacum pipes somewhere. Probably a guide on the main page if you have a search about.
- GuardianAngel
12 years 11 months ago #96440
by GuardianAngel
Replied by GuardianAngel on topic 4wd light blinking
The first and most likely culprit is the vacuum hoses/pipes have split/corroded. You will need to get the front wheels off and also get under the J and trace the pipes to see where the problem is.
Try Googling "Jimny 4wd light flashing". There is a whole host of threads on the subject.
Your best bet though is to fit manual hubs, which means you don't have to worry about this at all
- jonesyba420
12 years 11 months ago #96441
by jonesyba420
+1 easiest way to find stuff out and 90% of the time it will point you here anyway
GuardianAngel wrote: Try Googling "Jimny 4wd light flashing". There is a whole host of threads on the subject.
- gilburton
12 years 11 months ago #96442
by gilburton
Replied by gilburton on topic 4wd light blinking
No you are not in 4WD if you do not have the light staying on.
Try putting the clutch fully to the floor.
DO NOT run the Jimny in 4WD on tarmac you'll break it!!
- greenjimny
12 years 11 months ago #96465
by greenjimny
the 4wd light blinks when there is a vacuum problem as stated in the prior two posts !
Replied by greenjimny on topic 4wd light blinking
gilburton wrote: No you are not in 4WD if you do not have the light staying on.
