215 75 R15 on 15" x 7j
  • macguyverjimny
05 Dec 2013 15:00 #94650 by macguyverjimny
215 75 R15 on 15" x 7j was created by macguyverjimny
Hi guys,
It is wize to fit 215 75 r15 to 15 " 7j rims?
And then maybe fit 235's in the future?
The supplier i contacted said his 15" rims starts from 7j ,
Any help or advise would be apprciated.
Also the car is lifted 2" and with front bar,
Thank you :)
  • macguyverjimny
05 Dec 2013 22:29 #94722 by macguyverjimny
Replied by macguyverjimny on topic 215 75 R15 on 15" x 7j
Any reason why i should avoid these 7j rims at all costs? On 215 75 R15
Thank you :)
  • Reloaded
06 Dec 2013 08:54 #94749 by Reloaded
Replied by Reloaded on topic 215 75 R15 on 15" x 7j
They should fit fine, here's a table of recommended rim sizes for different tyre widths:
www.brick-yard.co.uk/forum/tyre-size-for...idth_topic60146.html
  • helijohn
06 Dec 2013 22:09 #94852 by helijohn
Replied by helijohn on topic 215 75 R15 on 15" x 7j
I'm running 205 70 15s on 7x15 rims and there is a fair amount of room. I was going to go to 75s, I had measured up and expected them to be fine and don;t forget many use that size on regular rims but these tyres came up at a bargain price.
  • iloveics
06 Dec 2013 22:40 #94860 by iloveics
Replied by iloveics on topic 215 75 R15 on 15" x 7j
macguyverjimny wrote: Any reason why i should avoid these 7j rims at all costs? On 215 75 R15
Thank you :)
If your fitting the tyres to the wheels yourself, be prepared for a fight.
I did mine and the wheels are far to wide in my opinion, I had to put the tyre on the wheel then balance the tyre between two wheels and jump up and down on the wheel to push most of one bead on, then turn it over and push the wheel through whilst putting air in it.
  • Lecras
07 Dec 2013 00:26 #94881 by Lecras
Replied by Lecras on topic 215 75 R15 on 15" x 7j
Just fitted this size on my Jimny and they are great, No problem fitting them (plenty of lube!!!) and no rubbing with no mods!
Time to create page: 0.160 seconds
