Jimny Wheels
- Tadpole
25 Nov 2013 20:40 #93189
by Tadpole
Jimny Wheels was created by Tadpole
I am thinking about making a change of wheels on my 'standard' set up Jimny fitted at present with Brembo rims.
Will a rim marked 7J fit with standard tyres 205 x 70 x 15 ie is this 'offset' ok
- deedar
25 Nov 2013 20:47 #93192
by deedar
Replied by deedar on topic Jimny Wheels
Should do if the offset is okay
29 Nov 2013 22:58 #93937
by jimkyx
Replied by jimkyx on topic Jimny Wheels
205 on a 7 inch rim is stretching it a bit!
- Thank you received: 2004
30 Nov 2013 07:30 - 30 Nov 2013 07:33 #93952
Replied by Lambert on topic Jimny Wheels
The 7 relates to the width of the wheel as measured between the inside edges of the rim upstand. J relates to the shape of the upstand that the bead of the tyre sits on. What you need to know is the 'et' value of the wheel as that is the offset or inset, it is the distance between the mounting face of the wheel and it's centre line viewed end on. Negative offset is the face to the inside of the centre line positive is to the outside of the centre line. The more negative the more the wheel protrusion from the arch, good for stability bad for wheel bearings and mot.
Last edit: 30 Nov 2013 07:33 by Lambert.
- Reloaded
30 Nov 2013 08:34 #93956
by Reloaded
Replied by Reloaded on topic Jimny Wheels
Here's a table
of recommended tyre sizes for rim width.
- Tadpole
30 Nov 2013 09:30 #93961
by Tadpole
Replied by Tadpole on topic Jimny Wheels
Cheers guys, I have decided to give them a miss as I am unable to find out anymore info on them .....
Time to create page: 0.090 seconds
