Cab misting up!
  • brianjb61
23 Nov 2013 19:00 #92795 by brianjb61
Cab misting up! was created by brianjb61
Hi all, has anyone any ideas where to look? This morning when I fired up little Jim and put the blower on to demist the screen there is a smell similar to warm engine coolant! The cab is constantly misting up and the air feels really damp. I've checked the coolant level and thats fine, checked the carpets up under the footwell for leaks and they are dry and I got no air con to worry about. Thanks.
  • Tommo
23 Nov 2013 20:14 - 23 Nov 2013 20:17 #92809 by Tommo
Replied by Tommo on topic Cab misting up!
where do you have the air coming in from,
the external air option on the dash
or do you circulate the air from inside?
I tried circulating the air in side for a month, to see if it warms up any quicker
and it doesn't. All it does is get damp over time, and then stay damp and foggy inside
because jimny's don't have air con ( I don't know about newer ones)
but mine doesn't and its 2003
they don't dehumidify, being small they fog up really quickly,
it gets really bad if it's rainy, with a wet coat, wet shoes etc you get in and it makes it worse lol
all you can do when it's really bad is have the heating on full and have the
window ajar to let the moisture out
Last edit: 23 Nov 2013 20:17 by Tommo. Reason: spelling
  • helijohn
23 Nov 2013 21:11 #92829 by helijohn
Replied by helijohn on topic Cab misting up!
brianjb61 wrote: Hi all, has anyone any ideas where to look? This morning when I fired up little Jim and put the blower on to demist the screen there is a smell similar to warm engine coolant! The cab is constantly misting up and the air feels really damp. I've checked the coolant level and thats fine, checked the carpets up under the footwell for leaks and they are dry and I got no air con to worry about. Thanks.
It certainly sounds like a coolant leak in the cab doesn't it but maybe the water is in the heater air intake?
  • Dave cc
23 Nov 2013 21:15 #92832 by Dave cc
Replied by Dave cc on topic Cab misting up!
Heater matrix leaking me reckons gives you a sore throat as well if you are breathing it long enuf :(
  • helijohn
23 Nov 2013 21:20 #92834 by helijohn
Dave cc wrote: Heater matrix leaking me reckons gives you a sore throat as well if you are breathing it long enuf :(
No loss of coolant though????? :unsure:
  • RichiesJimny
23 Nov 2013 21:56 #92848 by RichiesJimny
Replied by RichiesJimny on topic Cab misting up!
My guess would be heater matrix put some K seal in the radiator and see if that stops the misting
Time to create page: 0.210 seconds
