Castor correction
  • Tommo
12 years 11 months ago #92443 by Tommo
Castor correction was created by Tommo
What's better
To buy the bushes
Or the propper arms?
I have a 3" spring lift
  • idiotmobil
12 years 11 months ago #92447 by idiotmobil
Replied by idiotmobil on topic Castor correction
arms are really needed for 3" im on 3 " after being on 2" with bushes and still have the bushes it was good on the 2" but with the 3" its not perfect still reasonable on the road but I what arms now so be best to go straight for arms they are expensive but you also get a stronger arm so there's two advantages
also ive been told with out correction the springs are bowed and this loses some of the articulation and I would guess a little lift
  • macguyverjimny
12 years 11 months ago #92528 by macguyverjimny
Replied by macguyverjimny on topic Castor correction
Get the arms,
I had the CC bushes and its not sufficient,
The arms also push the axle forward, and also change the angle at which the spring sits,
And get the right stuff, i tried to go the cheap route, but get the right stuff, 3" coils, 3" shocks, shock relocators at the back, extended brake lines, prop spacer of needed, caster correction, pamhard correction :)
All the best, be carefull if you do go with extended brake lines so you dont bend the alu tube withe you are doing the instalation, mine bended after trying to switch the coils around,
And then suddenly my tires look like small standard HT. tyres :)
Hope this help.
  • idiotmobil
12 years 11 months ago #92531 by idiotmobil
i agree except pan hard arms mine has standered and she sits straight ive seen a few others like this to
  • winter
12 years 11 months ago #92549 by winter
Replied by winter on topic Castor correction
hi iv got 3 1/2" lift was running cc bushes but now made my own cc arms and what a differents they have made now looking back on things them bushes are shit spend the money shes so much sure footed on and off road plus got a little more arch space win win fook off the bushes and get the cc arms :)
Tommo wrote: What's better
To buy the bushes
  • Wiltec17
12 years 11 months ago #92580 by Wiltec17
Replied by Wiltec17 on topic Castor correction
I've got 3" correction bushes and they seem ok on mine. They are t recommended for off road use though :/ they have had some abuse so far and faired ok. I only got them because there cheap I didn't have the cash for arms though :pinch:
Time to create page: 0.087 seconds
