Crankshaft Oil Seal
12 Nov 2013 14:22 - 21 Nov 2013 15:11 #90603 by SpeeLaT
Crankshaft Oil Seal was created by SpeeLaT
Anyone know the size and any special codes needed for the REAR Crankshaft Oil seal. Trying to get all the bits together before I strip it down.
I think I have the codes MHSA XRT just need the size
Special Codes = Double lip or directional etc LLU
If anyone wants to know
MHSA = Standard type seal
XRT = Helix Seal usually used in crankshafts and Cams is rotational helps pump oil back into the engine.
XRT = Front
XLT = Rear
Last edit: 21 Nov 2013 15:11 by SpeeLaT.
  • srcars
12 Nov 2013 19:00 #90636 by srcars
Replied by srcars on topic Crankshaft Oil Seal
Hi, which engine do you have ? I did mine a couple of years ago on the sohc g13bb. After a lot of messing I was forced to order mine through local stealer. According to their invoice the part number was 09283-68002-000 description was 'rear oil seal (68x86x8)' and they relieved me of £20 for it. A local bearing company came close but as I recall it was only a single directional one and he didn't recommend it and another motor factors said yes but when it arrived it was half the diameter so in the end I just paid up for original part. Hope that helps Rich
12 Nov 2013 19:41 #90651 by SpeeLaT
Replied by SpeeLaT on topic Crankshaft Oil Seal
Thanks for that I was sure it would be those dimensions from what I have managed to glean from the internet. Much appreciated
20 Nov 2013 16:35 #92326 by SpeeLaT
Heads up anyone wanting to do this job. The Suzuki oil seal is £29.16inc
But if you are not too bothered to bend over you can get one from an FAI outlet part number OS378 for £5
Here are the cross references for the REAR Crankshaft Oil Seal
AJUSA 15032100
BRITISH GASKETS OS3312
ELRING 505293
FIRSTLINE OS515
PAYEN NJ378
Hope it helps
  • Reloaded
20 Nov 2013 17:09 #92333 by Reloaded
Replied by Reloaded on topic Crankshaft Oil Seal
SpeeLaT wrote: Heads up anyone wanting to do this job. The Suzuki oil seal is £29.16inc
AJUSA 15032100
ELRING 505293
FIRSTLINE OS515
PAYEN NJ378
Hope it helps
Good info there mate - hope I can find it if and when I need one lol
  • srcars
20 Nov 2013 18:33 #92347 by srcars
Hope you don't need to find the info as the job was a right PITA :laugh:
