seal help
  • rut
30 Oct 2013 21:54 #88661 by rut
seal help was created by rut
Hi
can this seal in the photo below be replaced and if so can anyone tell me what it is called and possibly a part number, as i can't find one any where
http://
[IMG
i tried to order two from suzuki dealer first they sent me the Swivel Hub Seal then they sent these which i think are the inner wheel bearing seals
[IMG
and i don't want to spend money fitting manual hubs when all i need is this seal
hope someone can help thanks in advance
rut
  • vitara_mad
30 Oct 2013 23:02 #88670 by vitara_mad
Replied by vitara_mad on topic seal help
can you not just remove the seal & take it somewhere local the does bearings & seals
alternatively ive got a few pairs of the vacume hubs if u want a pair
  • Dunnin21
31 Oct 2013 18:57 #88778 by Dunnin21
Replied by Dunnin21 on topic seal help
Instant gasket sealer always worked fine for me, if you cant find any
  • markyp2000
31 Oct 2013 19:08 #88782 by markyp2000
Replied by markyp2000 on topic seal help
Are you talking about the seal with 6 holes or the rubber seal that runs on the hub nut that may come with a new wheel bearing
  • rut
31 Oct 2013 19:54 #88800 by rut
Replied by rut on topic seal help
im talking about the rubber seal in the center the gasket with the six holes is ok,
the rubber seal has a chunk missing, if i put tigger seal or a smear of silicone on it it works perfect for a wile until iv done a few miles then with the center of the hub running on the seal it loses it vacume.
im sure it must be possible to replace it if i could find were to get one, or even the name of that seal.
thanks for your replies
  • markyp2000
31 Oct 2013 22:06 #88832 by markyp2000
Main dealer and see if thay do the seal that rund on the hub nut
Time to create page: 0.121 seconds
