think my engine has gone or going ? help
- bashley
21 Oct 2013 21:55 #87429
by bashley
Replied by bashley on topic think my engine has gone or going ? help
Dont no if this will help I had same sort of problem I was fiting a stereo and my battery was on its last legs the ecu of a jimny needs more than 8v to work if its low they dont tick over or run properly all the lights flash on the dash and needles move I charged for an hr or 2 and was fine after but I ended up buying a new battery hope this helps buddy
- vitara_mad
21 Oct 2013 22:16 #87434
by vitara_mad
Replied by vitara_mad on topic think my engine has gone or going ? help
hopefully you wont need a engine jon but if you did they are straight forward fit
- Dave cc
21 Oct 2013 22:25 #87436
by Dave cc
Had the same issue this week when we tried to use my jim to start my hilux was not at all happy was miss firing and running rough as hell as we cranked my hilux over as you say think battery voltage was dropping so low the ECU was shouting enuf is enuf
Replied by Dave cc on topic think my engine has gone or going ? help
bashley wrote: Dont no if this will help I had same sort of problem I was fiting a stereo and my battery was on its last legs the ecu of a jimny needs more than 8v to work if its low they dont tick over or run properly all the lights flash on the dash and needles move I charged for an hr or 2 and was fine after but I ended up buying a new battery hope this helps buddy
- jamesey
22 Oct 2013 06:53 #87450
by jamesey
Replied by jamesey on topic think my engine has gone or going ? help
Ill see what its like later ive got a big battery to put jump leads on to try it.fingers crossed
- jonesyba420
22 Oct 2013 07:25 #87452
by jonesyba420
Replied by jonesyba420 on topic think my engine has gone or going ? help
Same problem with my Ibiza turbo when I sold it, had been sat for months so the battery was completely dead! Jump started it after much persuation and it then ran like a bag of shi* till the battery charged abit was flashing warning lights at me missfiring the works.once it charged up it was fine
- jamesey
23 Oct 2013 07:20 #87576
by jamesey
Started fine last night .so maybe a glitch?
Or something might be on its way
Time to create page: 0.210 seconds
