Heater Control Lights
- Adamski
10 Oct 2010 19:18 #5065
by Adamski
Heater Control Lights was created by Adamski
When I switch my headlights on all the dash lights come on fine apart from the lights behind the heater controls. Does anyone have any suggestions as to where I should look first to rectify it? Is this a common fault on the Jimny's?
- ooky_123
10 Oct 2010 19:30 #5067
by ooky_123
Replied by ooky_123 on topic Re: Heater Control Lights
Interesting you should say that ... My Wife's old Jimny (1999 soft top) didnt have heater illumination, neither does our 2001 hard top ... but my fathers 2001 "51" Plated Jimny does ...
Not sure if its a common problem, but I too have wondered if they should come on or not.
- Adamski
10 Oct 2010 19:35 #5068
by Adamski
I'm sure it mush have lights behind the controls, my mothers 2005 Soft top has lights and it is surprising how hard it is to see the controls at night without the lights, as im sure you know. I've yet to do the basics like fuses etc but just wondered if anyone would have a quick answer which would save me having to track the cause of the fault down. Hopefully it will solve both our problems
Replied by Adamski on topic Re: Heater Control Lights
ooky_123 wrote: Interesting you should say that ... My Wife's old Jimny (1999 soft top) didnt have heater illumination, neither does our 2001 hard top ... but my fathers 2001 "51" Plated Jimny does ...
10 Oct 2010 20:06 #5069
by facade
Replied by facade on topic Re: Heater Control Lights
On my 2001 Hardtop the long strip between the two levers lights up to show the little symbols. (pity you can't tell where the lever is without feeling it though)
Looks to be a bulb behind the panel in the middle, probably accessed from above the radio.
Does make the dash look nice, but as I said, not overly useful.
- mcjimny
10 Oct 2010 20:26 #5070
by mcjimny
Replied by mcjimny on topic Re: Heater Control Lights
I've had it where all the dash lights have come on except those then next time i switched them on they worked! Not repeated the problem since though.
I do have half my speedo out though, i can read it clear enough at night as it is so i'm waiting for a few more to go before i go to the bother of dismantling the dash to get to the binnacle....unless someone knows of a quick way?
- Nelson83
11 Oct 2010 14:49 #5076
by Nelson83
Replied by Nelson83 on topic Re: Heater Control Lights
Must be something more special about the "special" models - mine does the exact same thing Adamski - the heater controls light up sometimes and then other times not. I've solved the problem in true bloke style though - when it fails to illuminate - at short, sharp thump on the top of the dash, usually results in there being light :whistle: . It usually gets a few funny looks of passengers when i bash the top of the dash, but for how long it takes me to give it a "tap" its a lot quicker than stripping the dash apart.
Just another thought, your special model doesn't have a little quirky feature that the hand brake light stays on even when the hand brake is totally off does it? I've had this since i bought mine just over 3 years ago and my light sometimes stays on for a short while, others for a whole 3 hour journey and the rest of the time its off. Its fairly random as to when it decides to stay on, but sometimes the hot weather (what we get) affects it. I just live with it as being part and parcel of my truck, but am wondering if mines extra special, or if all jimnys have the same problem.
Time to create page: 0.173 seconds
