having problems with my 4x4 system!!
- chrisharman
10 Aug 2013 10:01 #79457
by chrisharman
having problems with my 4x4 system!! was created by chrisharman
When reversing in four wheel drive on full lock it locks up and fills like
the brakes come on.
The 4wd light is flashing.
Any help??
the brakes come on.
Any help??
10 Aug 2013 10:21 - 10 Aug 2013 10:23 #79458
by facade
Replied by facade on topic having problems with my 4x4 system!!
The 4wd light flashes if there is something wrong with the vacuum system, because it doesn't think the hubs engaged.
However, driving on full lock on tarmac is trying to snap the halfshafts off, so I'm guessing someone has jammed the hubs in engagement.
Never never never never try and drive on full lock in 4wd on tarmac, it puts tremendous strain on the 4wd system, and will end in tears eventually, when something breaks, usually a CV joint.
The 4wd is designed for low traction surfaces, like mud.
Put it in 2wd with the engine running and drive a few metres park up, then crawl underneath.
If you cannot rotate the front propshaft the hubs are permanently engaged.
There is plenty of info on here about testing the vacuum system, or bypassing it and fitting manual hubs (have you got them already?)
EDIT: If it is locking up only in 4wd on full lock, on nice slippery mud, I'd investigate the CV joints at the front.
Last edit: 10 Aug 2013 10:23 by facade.
- markyp2000
10 Aug 2013 11:44 #79462
by markyp2000
Replied by markyp2000 on topic having problems with my 4x4 system!!
Sounds like your getting whats called wind up due to not having a center diff and when the front wheels are turned the inner wheel will run slower than the outer wheel this is on tarmac in 4wd if on a slippery surface it should be fine as all wheel should turn at the same speed due to wheels slipping
- chrisharman
11 Aug 2013 14:18 #79558
by chrisharman
Replied by chrisharman on topic having problems with my 4x4 system!!
Thanks for the advice.
If i get manual locking hubs with that solve the problem?
- markyp2000
11 Aug 2013 14:31 #79563
by markyp2000
Are you doing thos in 4wd or 2wd on tarmac or looses surface
- chrisharman
11 Aug 2013 14:33 #79564
by chrisharman
4wd lose tarmac
Time to create page: 0.089 seconds
