wiring roof lights
  • Poyner111
25 Jul 2013 16:16 #78171 by Poyner111
wiring roof lights was created by Poyner111
Hi all
I have made up my roof bar and added 4 No 55 watt spots, is someone able to run me through the wiring step by step and explain in plane English like they are talking to a 5 year old. :blush:
for example 2 No wires at the back of the light what is what ?
  • markyp2000
25 Jul 2013 16:23 - 25 Jul 2013 17:00 #78172 by markyp2000
Replied by markyp2000 on topic wiring roof lights
White is live earth is black put a ring terminal on the earth and conect it to the light bar
Run 4 wires from under the bonnet upto the lights for the live then you need to relay kits poss get from halfords then wire as in the relay kit
Use the search section to find a wiring diagram
Last edit: 25 Jul 2013 17:00 by markyp2000.
  • helijohn
25 Jul 2013 17:23 #78182 by helijohn
Replied by helijohn on topic wiring roof lights
Do you want to be able to select which lights you have on?
  • markyp2000
25 Jul 2013 17:30 #78184 by markyp2000
At the top of the Jimny Technical in the yellow box is some help also look here
www.bigjimny.com/index.php/forum/8-my-ji...ny-soft-top?start=48
  • Poyner111
25 Jul 2013 19:13 #78203 by Poyner111
Replied by Poyner111 on topic wiring roof lights
Wow bit fancy hasn't crossed my mind prob not just to add in to the high beam switch or seperate switch
  • Poyner111
25 Jul 2013 19:15 #78204 by Poyner111
Assume ill need two kits ?
Time to create page: 1.557 seconds
