wiring roof lights
- Poyner111
25 Jul 2013 16:16 #78171
by Poyner111
wiring roof lights was created by Poyner111
- markyp2000
25 Jul 2013 16:23 - 25 Jul 2013 17:00 #78172
by markyp2000
Replied by markyp2000 on topic wiring roof lights
White is live earth is black put a ring terminal on the earth and conect it to the light bar
Run 4 wires from under the bonnet upto the lights for the live then you need to relay kits poss get from halfords then wire as in the relay kit
Use the search section to find a wiring diagram
Last edit: 25 Jul 2013 17:00 by markyp2000.
25 Jul 2013 17:23 #78182
Replied by helijohn on topic wiring roof lights
Do you want to be able to select which lights you have on?
- markyp2000
25 Jul 2013 17:30 #78184
by markyp2000
At the top of the Jimny Technical in the yellow box is some help also look here
www.bigjimny.com/index.php/forum/8-my-ji...ny-soft-top?start=48
- Poyner111
25 Jul 2013 19:13 #78203
by Poyner111
Replied by Poyner111 on topic wiring roof lights
Wow bit fancy hasn't crossed my mind prob not just to add in to the high beam switch or seperate switch
- Poyner111
25 Jul 2013 19:15 #78204
by Poyner111
Assume ill need two kits ?
Time to create page: 1.382 seconds
